i have the following issue with multiple SSIDs on Spitz AX (X3000) / Beryl AX (MT3000):
I have edited the config files according to the following Guide from GL.inet. The result is that i have an additional 2.4 and 5 GHz SSID, wich I can’t connect to, if i change option ifname to “ra2” or “rax2”. If I change option ifname to “ra1” or “rax1” i can connect to the SSID, but activating the new SSID overrides the second SSID, so that I can either activate the guest network or the new SSID. If I activate both, only the new SSID works and the guest SSID isn’t available anymore.
Editing the MaxBssidNum didn’t change anything.
Cany anyone help me with getting all three of my SSIDs to work?
I have configured SIoT as an own interface via Luci and restarted multiple times. If S-IOT has the iFrame ra1, respective rax1 I can connect, but activating S-IOT results in my guest network not beeing broadcasted. Attributing ifname ra2/rax2 results in not beeing able to connect.
Because the encryption you configured is sae-mixed.So you need to make sure your phone supports sae encryption. Older devices do not support this encryption.
