Here’s some of the log.
All I did was:
load firmware, changed password (so I could login to GUI), synched time with browser, manually entered APN and password.
Modem: EP06 , Carrier: EE UK, APN “everywhere” (set manually as auto-setup doesn’t work on any 4.x firmware version.
Fri Mar 24 15:47:58 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+CGDCONT=1,“IP”,“everywhere”
data_leangth=0 data=
OK
Fri Mar 24 15:47:58 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+QICSGP=1,1,“everywhere”,“eesecure”,“secure”,1
OK
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2_4 (11906): udhcpc: received SIGTERM
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2_4 (11906): udhcpc: entering released state
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:488] call_end_reason is 1018
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:488] call_end_reason_type is 6
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:489] call_end_reason_verbose is 33
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:552] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:552] call_end_reason is 1018
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:552] call_end_reason_type is 6
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:553] call_end_reason_verbose is 33
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:46:20:553] try to requestSetupDataCall 60 second later
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:712] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:712] call_end_reason is 1018
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:712] call_end_reason_type is 6
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:713] call_end_reason_verbose is 33
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:776] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:776] call_end_reason is 1018
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:776] call_end_reason_type is 6
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:777] call_end_reason_verbose is 33
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:20:777] try to requestSetupDataCall 60 second later
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:59:562] QmiWwanThread exit
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (11833): [03-24_15:47:59:563] qmi_main exit
Fri Mar 24 15:47:59 2023 daemon.notice netifd: Interface ‘modem_1_1_2’ is now down
Fri Mar 24 15:47:59 2023 daemon.notice netifd: Interface ‘modem_1_1_2’ is setting up now
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2_4 (11906): Command failed: ubus call network.interface notify_proto { “action”: 0, “link-up”: false, “keep”: false, “interface”: “modem_1_1_2_4” } (Permission denied)
Fri Mar 24 15:47:59 2023 daemon.notice netifd: Interface ‘modem_1_1_2_4’ is now down
Fri Mar 24 15:47:59 2023 daemon.notice netifd: Interface ‘modem_1_1_2_4’ is disabled
Fri Mar 24 15:47:59 2023 daemon.notice netifd: Network alias ‘’ link is down
Fri Mar 24 15:47:59 2023 daemon.notice netifd: Interface ‘modem_1_1_2_4’ has link connectivity loss
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (22991): sh: 0: unknown operand
Fri Mar 24 15:47:59 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=‘AT+QNWPREFCFG=“roam_pref”,255’
ERROR
Fri Mar 24 15:47:59 2023 daemon.notice netifd: modem_1_1_2 (22991): ERROR
Fri Mar 24 15:48:00 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=ATI
Quectel
EP06
Revision: EP06ELAR03A08M4G
OK
Fri Mar 24 15:48:00 2023 daemon.notice netifd: modem_1_1_2 (22991): Failed to parse message data
Fri Mar 24 15:48:00 2023 daemon.notice netifd: modem_1_1_2 (22991): sh: 0: unknown operand
Fri Mar 24 15:48:00 2023 daemon.notice netifd: modem_1_1_2 (22991): sh: 1: unknown operand
Fri Mar 24 15:48:01 2023 user.notice mwan3[22926]: Execute ifdown event on interface modem_1_1_2 (unknown)
Fri Mar 24 15:48:01 2023 user.info mwan3track[12555]: Detect ifdown event on interface modem_1_1_2 (wwan0)
Fri Mar 24 15:48:01 2023 user.notice mwan3track[12555]: Interface modem_1_1_2 (wwan0) is offline
Fri Mar 24 15:48:01 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:01:781] QConnectManager_Linux_V1.6.3.1
Fri Mar 24 15:48:01 2023 daemon.notice netifd: Interface ‘modem_1_1_2’ is now up
Fri Mar 24 15:48:01 2023 daemon.notice netifd: Network device ‘wwan0’ link is up
Fri Mar 24 15:48:01 2023 daemon.notice netifd: Network alias ‘wwan0’ link is up
Fri Mar 24 15:48:02 2023 daemon.notice netifd: Interface ‘modem_1_1_2_4’ is enabled
Fri Mar 24 15:48:02 2023 daemon.notice netifd: Interface ‘modem_1_1_2_4’ has link connectivity
Fri Mar 24 15:48:02 2023 daemon.notice netifd: Interface ‘modem_1_1_2_4’ is setting up now
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2_4 (23186): udhcpc: started, v1.35.0
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:01:836] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x306, bus=0x001, dev=0x004
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:01:862] Auto find qmichannel = /dev/cdc-wdm0
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:01:863] Auto find usbnet_adapter = wwan0
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:01:863] netcard driver = qmi_wwan, driver version = 5.10.146
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:01:865] Modem works in QMI mode
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:029] cdc_wdm_fd = 7
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:216] Get clientWDS = 20
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:280] Get clientDMS = 1
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:344] Get clientNAS = 3
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:408] Get clientUIM = 3
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:472] Get clientWDA = 1
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:536] requestBaseBandVersion EP06ELAR03A08M4G
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:792] requestGetSIMStatus SIMStatus: SIM_READY
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:856] requestGetProfile[1] everywhere/eesecure/secure/1/IPV4
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:856] requestSetProfile[1] everywhere/eesecure/secure/1/IPV4
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:857] no need to set skip the rest
Fri Mar 24 15:48:02 2023 daemon.notice netifd: modem_1_1_2 (23121): [03-24_15:48:02:924] requestRegistrationState2 MCC: 234, MNC: 30, PS: Attached, DataCap: LTE
Fri Mar 24 15:48:03 2023 daemon.notice netifd: modem_1_1_2_4 (23186): udhcpc: broadcasting discover
Fri Mar 24 15:48:06 2023 daemon.notice netifd: modem_1_1_2_4 (23186): udhcpc: broadcasting discover
Fri Mar 24 15:48:09 2023 daemon.notice netifd: modem_1_1_2_4 (23186): udhcpc: broadcasting discover
Fri Mar 24 15:48:09 2023 user.notice firewall: Reloading firewall due to ifdown of modem_1_1_2 ()
Fri Mar 24 15:48:14 2023 user.notice mwan3[23780]: Execute ifup event on interface modem_1_1_2 (wwan0)
Fri Mar 24 15:48:15 2023 user.notice mwan3[23780]: Starting tracker on interface modem_1_1_2 (wwan0)
Fri Mar 24 15:48:18 2023 user.info mwan3rtmon[12645]: Detect rtchange event.
Fri Mar 24 15:48:21 2023 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2 (wwan0)
Fri Mar 24 15:48:56 2023 user.notice mwan3[24979]: Execute ifdown event on interface modem_1_1_2 (wwan0)
Fri Mar 24 15:48:58 2023 user.notice firewall: Reloading firewall due to ifdown of modem_1_1_2 (wwan0)
Fri Mar 24 15:49:02 2023 user.info mwan3track[24013]: Detect ifdown event on interface modem_1_1_2 (wwan0)
Fri Mar 24 15:49:07 2023 user.notice mwan3track[24013]: Interface modem_1_1_2 (wwan0) is offline
Fri Mar 24 15:50:44 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+CPMS=“ME”,“ME”,“ME”
+CPMS: 0,23,0,23,0,23
OK
Fri Mar 24 15:50:44 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+CGPADDR
+CGPADDR: 1,“10.180.88.167”
+CGPADDR: 2,“”
+CGPADDR: 3,“”
OK
Fri Mar 24 15:50:44 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+CPIN?
+CPIN: READY
OK
Fri Mar 24 15:50:44 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+ICCID
+ICCID: xxxxxxxxx
OK
Fri Mar 24 15:50:44 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+QCCID
+QCCID: xxxxxxxxx
OK
Fri Mar 24 15:50:44 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+CIMI
xxxxxxxxx
OK
Fri Mar 24 15:50:44 2023 daemon.err modem_AT: (modem_AT.c:314) cmd=AT+CNUM
+CNUM: “Own Number”,“xxxxxxxxxxxx”,129
:::::::::::::working
Fri Mar 24 16:33:18 2023 daemon.err usbmuxd[5044]: [16:33:18.424][3] usbmuxd v1.1.1 starting up
Fri Mar 24 16:33:18 2023 daemon.err usbmuxd[5044]: [16:33:18.450][3] Using libusb 1.0.24
Fri Mar 24 16:33:18 2023 daemon.err usbmuxd[5044]: [16:33:18.479][3] Initialization complete
Fri Mar 24 16:33:18 2023 daemon.err usbmuxd[5044]: [16:33:18.480][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with “–exit” to trigger.
Fri Mar 24 16:33:19 2023 user.notice firewall: Reloading firewall due to ifup of guest (br-guest)
Fri Mar 24 16:33:30 2023 user.notice mwan3[5591]: Execute ifup event on interface lan (br-lan)
Fri Mar 24 16:33:30 2023 user.notice mwan3[5591]: Starting tracker on interface lan (br-lan)
Fri Mar 24 16:33:33 2023 user.info mwan3rtmon[4902]: Detect rtchange event.
Fri Mar 24 16:33:35 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Fri Mar 24 16:33:39 2023 user.notice mwan3[6049]: Execute ifup event on interface loopback (lo)
Fri Mar 24 16:33:39 2023 user.notice mwan3[6049]: Starting tracker on interface loopback (lo)
Fri Mar 24 16:33:42 2023 user.info mwan3rtmon[4902]: Detect rtchange event.
