how can i install shadowsocksR to ar150.,.,
Hey, you can refer to this thread. GL-MT300N-V2 ShadowsocksR (SSR) ipk - #16 by acercow
Someone has uploaded those ipks to Google drive.
thanks i installed it succesfully but idont know why when i put my server it wont run.,.but same server and setup on ssr app on pc and android it is working
Do you mean the process hasn’t started?
yes.,.when you look at status its not running
I hadn’t been used SSR, I will let you know when I try it.
After installing the ipk, you have to reboot the device. After reboot, you can select a global server, then click on Apply & Save, it should work.
