Starlink IPv6 needs ndisc6 package
Story short, setting up IPV6 on Starlink needs the router to send sollicitation to the wan dhcpv6 each 60sec.
This is done using rdisc6 from ndisc6 tools.
I’d like to know if the package can be added to the repository.
Thanks
@GL, @hansome : Related thread & makefile:
@Kipk
Here’s an interesting comment on that same thread using option soltimeout 60:
I’ve already tried to use the makefile from this thread, but it doesn’t goes further with some compile error.
I could compile just the binary btw and put it on the router. But it’s not a viable solution for following updates . Would be nice to have it officially
The netifd approach doesn’t work either, it’s only called once a boot.
Yeah, agreed: I ping’d a pretty active GL staff member for that reason but I wouldn’t go as far as guaranteeing anything. I’m not seeing any rdisc or ndisc in the upstream packages:
Drats. It was worth a shot.
I’ve never used Starlink. What’s the purpose of this solicitation traffic? Is it just to keep a ‘heartbeat’ by periodically pushing a packet every 60 secs or does it require some very, very specially crafted encapsulation to have it register? If the former, I’m wondering if a simple watchcat to 9.9.9.9 or 1.1.1.1 wouldn’t do it:
Yes it needs to send an ICMPv6 Router Discovery packet ( what rdisc6 does ) each 60 sec to keep the /56 prefix lease alive.
If not the router just get a /64 prefix after few minutes and the whole network stays with local adresses only.
I don’t know why Starlink needs this, it probably won’t be the case I hope when IPV6 will be officially available on SL as it’s out of RFC
Here is what the multicast packet looks like:
Frame 1 (62 bytes on wire, 62 bytes captured)
Ethernet II, Src: 00:1b:11:52:bf:ab (00:1b:11:52:bf:ab), Dst: 33:33:00:00:00:02 (33:33:00:00:00:02)
Destination: 33:33:00:00:00:02 (33:33:00:00:00:02)
Address: 33:33:00:00:00:02 (33:33:00:00:00:02)
… …1 … … … … = IG bit: Group address (multicast/broadcast)
… …1. … … … … = LG bit: Locally administered address (this is NOT the factory default)
Source: 00:1b:11:52:bf:ab (00:1b:11:52:bf:ab)
Address: 00:1b:11:52:bf:ab (00:1b:11:52:bf:ab)
… …0 … … … … = IG bit: Individual address (unicast)
… …0. … … … … = LG bit: Globally unique address (factory default)
Type: IPv6 (0x86dd)
Internet Protocol Version 6
Source: fe80::21b:11ff:fe52:bfab (fe80::21b:11ff:fe52:bfab)
Destination: ff02::2 (ff02::2)
Internet Control Message Protocol v6
Type: 133 (Router solicitation)
Code: 0
Checksum: 0xab1e [correct]
I referred to this link and compiled an ndisc6 ipk by github action:
@Kipk you can download the Artifacts ipk for AX1800
You can also use the repo GitHub - luochongjun/gl-sdk-action: GL路由器应用软件包编译ACTION to compile your own.
great @hansome some
I also was not aware of this gl-sdk-action repo, thanks for pointing it.
can you add support for x3000 / X750 / BE9300, or better yet add ndisc6 package to the repo since this is commonly used for IPv6 support? Thanks
Do you have any preset for MT6000? I can’t seem to figure out the way to set this tool up
Could you help me with getting this for the MT6000. I’ve done everything I found to setup IPv6 for Starlink and still don’t get IPv6 addresses.
I'll ask my colleague to help compile and add it.
Thank you
It has been added to soft repository, you can update for mt6000:
opkg update
opkg install ndisc6
Here is the source FYI
gl-feeds/ndisc6 at common · gl-inet/gl-feeds · GitHub
In case of data sync delay, uploaded the IPK here:
ndisc6_1.0.8-1_aarch64_cortex-a53.zip (10.5 KB)
