Starlink with Beryl AX No Internet
I have bypassed the starlink router and have been using an old mikrotik hap ac with no problem. However, connecting the starlink to my new Beryl ax I show that I have an internet connection, but it is unusable (pages timeout etc.) I get the expected IP address from the dish (100.98.54.207) but I notice that the gateway is very different that when I use the mikrotik router. 34.120.255.244 instead of 100. something.
What change(s) are needed to the beryl configuration to use starlink connected directly to it?
Hi seekingsanity:
The support team has received your email, please communicate in the email.
Hi there!
I have just purchased a Beryl AX router and are having the exact same issues!
Can anyone tell me what im missing here?
Internet connection is apparently active, but no pages load! :frowning:
After a few exchanges with tech support with no progress, they then connected to my router remotely. They were unable to solve the problem, nor was I. I returned the AX and purchased a different brand. Working fine now.
Good luck.
Oh thats disappointing! What make/model did you end up with?
Still waiting for my Starlink Ethernet adapter but is this topic solved in the meantime?
Is Starlink as WAN link supported now? @dxf
Probably related:
