Although I put the Public IP of the Azure machine as the DNS of the WireGuard config, the dnsleaktest returns the WireGuard’s endpoint public IP and still no records on ADGH.
Yes. 20.x.x.x is the Azure ADGH Public IP. Screenshot is attached as well.
Encryption is enabled on ADGH. Is there anything I should configure on the router as well?
TBH, I am doing all this effort for one reason, from day 1 I have received my FLINT, I couldn’t enable ADGH locally as it crashes the router entirely every few minutes.
I have just noticed that OPENVPN works perfectly as expected and everything goes through Azure-ADGH.
But I want to use WireGuard instead due to the better connectivity speed compared to OPVN.
Would that give any clue?
Once I enabled custom DNS, both [DNS over TLS (Cloudflare or NextDNS) / Dnscrypt-Proxy Settings] greyed out.
I have already tested 3.214 and couldn’t notice a much better enhancement in the performance once ADG is enabled locally.
