Tailscale: "Allow Remote Access WAN" not Advertising Exit Node
I have several GLiNet routers I use at various houses to maintain a Tailnet. Today I replaced my main router with a GL-MT6000/Flint 2. After setting it up, however, I found that despite having connected to/enabling Tailscale and checking "Allow Remote Access WAN", this device is not advertising an exit node.
To be clear, it shows on my Tailnet, and I can configure the device (enabling the advertised subnets, for example), but I can't enable it as an exit node as it doesn't seem to be setting the appropriate flag.
I tried this out of the box, I then upgraded Tailscale using this script (which I do on all of my GLiNet devices), and found the exact same results. I've disabled and enabled Tailscale on the router and restarted the device - but the problem remains.
I also tried to SSH in and run tailscale up --advertise-exit-node, but still nothing.
Any thoughts or ideas?
Do you want to the Flint2 host the exit node of Tailscale?
Sorry but the GL GUI does not support this feature.
Please refer to this thread to manually configure:
Ah, thanks! Re-reading it I now see I misunderstood this toggle, and gl_tailscale appears to be exactly what I was poking around for last night in attempt to manually add the flag.
I'm a bit surprised this isn't in the UI at this point. I use a NAS as my main exit node, plus another on a VPS, but like having a backup at the same location as the NAS. Any reason for the omission? It seems a relatively simple function - easier than subnet routing.
Can you add it to the GUI or escalate to people higher up that can. This has been an issue for years, it can't be that hard to implement.
Sure, this request has been submitted to the PM team.
