Is going to be released a Tor version of the firmware for GL-MT300A and GL-MT300N? Because i’m going to buy one of the mini router according to Tor support. The GL-MT300A is a really powerfull mini router and i will be happy to have tor on it.
Hi, you need to move the switch button to the right side in order to access the UI. And you will not have Tor when you access the UI. After you setup please move the switch back.
I’m really interested in your amazing project that adds Tor support. I got a few questions and suggestions, as well. As a matter or fact, I’d like to give a donation to you.
Can you please tell me your bitcoin wallet number?
@Tamila, thanks for your donation. We are a commercial company so we don’t take donations now. If you like our products you can give us good reviews and buy more. Thanks!
Bugreport: I have found a big problem with firmware openwrt-mt300a-tor-1.4.bin
Apparently, TOR mode only works for LAN interface; WiFi traffic bypasses TOR and goes out “as is”, unprotected, which endangers WiFi users.
Would it be possible to fix that?
"When you move the switch to the left, it is in Tor.
When you move the switch to the right, you have normal Internet"
I remember this very well :)
Here are the results of testing the router by browser for address http://checkip.org :
Switch to the right (Normal):
LAN: IP = 95.133.11.28 (my real dynamic IP, Ukraine)
WAN: IP = 95.133.11.28 (my real dynamic IP, Ukraine)
Switch to the left (Tor):
LAN: IP = 109.163.234.7 (Romania, Tor is works)
WAN: IP = 95.133.11.28 (my real dynamic IP, Ukraine) - Tor here is not failure!
I just tested. I tried to set static IP and change wifi name as you do.
I don’t find any problem.
Basically the LAN port and WiFi is in the same sub network. The router routes all traffic from this sub network to Tor. So if LAN is on Tor, wifi is on Tor as well.
Are you sure you are not connecting to another wifi network? You can check your phone’s IP address to see if it is still 192.168.8.x if you don’t change LAN ip of the router.
If you are sure. Can you send me the content of /etc/config/network and /etc/firewall.user to have a check?
