@yuxin.zou
Hello, could I ask why the WireGuard support for Surfshark has been removed on the lastest update of the app?
It was very handy and they primary reason that I got Surfshark subscription was to work with my routers via WG protocol.
@yuxin.zou
The Surfshark API is temporarily unavailable, and we suspect that there is a tweak to the APIs. We’re working on a way to communicate with Surfshark so that when the API is available, Surfshark on the app will also be available.
Had to enter the password manually to connect my AR750 to the internet in repeater mode. It should be possible to use the camera or read a qr-code from a jpg/png-file when adding connections.
Thanks for your great suggestion, I will forward it to product manager.
Is there anyway to get TorGuard login back into the vpn section of the app? Noticed it been removed from the iOS app. Thanks.
Sorry that we have discontinued our partnership with TorGuard. So, there is no way to use TorGuard within the GL.iNet app anymore.
