Because yesterday, I installed firmware expressvpn(aircove), I tried 192.168.1.1. It not work
Yes, this is important!
Now is 2026.01.07 and aircoveOS version is 5.5.1.6514.
aircoveOS use a new uboot compiled at 2025.12.
You MUST USE NEW Method.
Reset Pin Method:
With device powered off press and hold the reset pin hole
Re-insert power to the device still with reset pin held and look at the lights.
The color change sequence of the Indicator Light is as follows:
—–Power ON—–
—–White Light—–
—–Blue Light—–
—–White Light—–(RELEASE RESET PIN NOW!!! Then You will enter U-Boot)
—–Blue Light—–(The opportunity has been missed; please start over from the first step.)
—–Blue Light—– -
Now in a web browser type
http://192.168.132.1/uboot.html -
Now Download and Flash GL.iNet U-boot (You can download from Post 22)
Immediately press and hold the Reset button without releasing it as you click to upgrade Uboot. Wait for the white LED to stay solid (approximately 5 seconds), then access 192.168.1.1 and flash the GL.iNet firmware.
