I bought EIOTCLUB card reader with physical SIM card and GL-X2000. Then bought Orange eSIM and tried installing.
First Windows PC, USB card reader, downloaded QR code, got
C:\Users\Adam\Downloads\EIOTCLUB_eSIM_reader-windows-x86_64-with-lpac\lpac.exe notification list
{"type":"lpa","payload":{"code":0,"message":"success","data":}}
C:\Users\Adam\Downloads\EIOTCLUB_eSIM_reader-windows-x86_64-with-lpac\lpac.exe profile download -s rsp-0004.oberthur.net -m [redacted]
{"type":"progress","payload":{"code":0,"message":"es10b_get_euicc_challenge_and_info","data":"rsp-0004.oberthur.net"}}
{"type":"progress","payload":{"code":0,"message":"es9p_initiate_authentication","data":"rsp-0004.oberthur.net"}}
{"type":"progress","payload":{"code":0,"message":"es10b_authenticate_server","data":"rsp-0004.oberthur.net"}}
{"type":"progress","payload":{"code":0,"message":"es9p_authenticate_client","data":"rsp-0004.oberthur.net"}}
{"type":"progress","payload":{"code":0,"message":"es10b_cancel_session","data":"rsp-0004.oberthur.net"}}
{"type":"progress","payload":{"code":0,"message":"es9p_cancel_session","data":"rsp-0004.oberthur.net"}}
{"type":"lpa","payload":{"code":-1,"message":"es9p_authenticate_client","data":"Refused"}}
Contacted support, got told to try on the router. Repeated the process via router interface, got
Device start connect internet
Internet connect success
Device start download profile
Download profile: 40%
Download profile fail: maybe this profile has been downloaded repeatedly by other devices or the current device, please check it or use other esim profile to test, if you confirm this is first time download, you can copy this logs to contact GL.iNet support get help.
Err message: Auth client fail. | { "header": { "functionExecutionStatus": { "status": "Failed", "statusCodeData": { "subjectCode": "8.8.2", "reasonCode": "3.8", "subjectIdentifier": "Security configuration", "message": "Refused" } } } }
The error looks the same - client authentication refused, cannot download profile, stops at 40%. I did not install the profile anywhere else.
Tried with QR code, with manual activation code entry, error persists. Any ideas? Thanks!
