Unable to add esim to mudi v2
Having a issue adding a esim to a Mudi v2, firmware up to date, using EIOT sim bought from gli.net.
esim gets to 90% the message:
Device start download profile
Download profile: 90%
Download profile: eSIM card storage space may be insufficient, please delete the old and no longer in use Profile and then download again
Err message:Load profile failed. |
only esim on the sim is the included seed profile which i don't see how to delete and don't wish to anyway.
any suggestions please?
esim supplier is spusu, they have sent me a replacement esim to try and had the same issue.
The default seed profile of eiot esim do not delete.
Please export the esim log for us to check from GL GUI > Application > esim manegement > esim log, when you import and load esim spusu profile.
Here is the log:
2025-02-06 20:08:33.064, DEBUG, main:31] lpaVer:1.47@owt.mips, debugOn:false, atMode:ubus, syncMode:on, mdReboot:5, seedAuto:false, delNotify:true
2025-02-06 20:08:33.078, DEBUG, main:34] config
2025-02-06 20:08:33.078, ERROR, config:57] open /root/esim/conf.json: no such file or directory
2025-02-06 20:08:33.078, DEBUG, main:38] db
2025-02-06 20:08:33.079, DEBUG, main:42] http
2025-02-06 20:08:33.079, DEBUG, main:46] at
2025-02-06 20:08:33.079, DEBUG, at:390] initAtServiceUbus
2025-02-06 20:08:33.079, DEBUG, main:54] ipa
2025-02-06 20:08:33.088, DEBUG, ipa:91] InitIpa
2025-02-06 20:08:33.088, DEBUG, at:87] UbusAtService.run
Thu Feb 6 20:08:33 2025
DBG, IPA_INIT, lib/esim/ipa2.c:559 [enter]
DBG, IPA_INIT, lib/esim/ipa2.c:574 [exit]
2025-02-06 20:08:33.095, DEBUG, main:63] agent
2025-02-06 20:08:33.111, DEBUG, agent:346] default.OnEnter
2025-02-06 20:08:33.121, DEBUG, agent:351] default.msg: default:next
2025-02-06 20:08:33.096, DEBUG, main:70] idle
2025-02-06 20:08:33.147, DEBUG, main:79] clean.log
2025-02-06 20:08:33.300, DEBUG, agent:368] imei:867228050091379
2025-02-06 20:08:33.301, DEBUG, agent:429] wakeup.OnEnter
2025-02-06 20:08:33.301, DEBUG, agent:435] wakeup.msg: wakeup:next
2025-02-06 20:08:33.465, DEBUG, agent:529] ready.OnEnter
2025-02-06 20:08:33.465, DEBUG, agent:537] ready.msg: ready:next
DBG, IPA_OPEN_CHANNEL, lib/esim/ipa2.c:658 [enter]
DBG, IPA_CLOSE_CHANNEL, lib/esim/ipa2.c:593 [enter]
DBG, IPA_CLOSE_CHANNEL, lib/esim/ipa2.c:596 [exit]
DBG, IPA_TRT_OPEN_CHANNEL, lib/esim/ipa2.c:600 [enter]
Thu Feb 6 20:08:34 2025
DBG, IPA_OPEN_CHANNEL_1_2, lib/esim/ipa2.c:643 [select 1 ok]
DBG, IPA_OPEN_CHANNEL, lib/esim/ipa2.c:665 [exit:0]
2025-02-06 20:08:34.881, DEBUG, agent:641] esim.OnEnter
2025-02-06 20:08:34.881, DEBUG, agent:651] esim.msg: esim:next
2025-02-06 20:08:34.882, DEBUG, agent:657] seed.auto: false
2025-02-06 20:08:34.882, DEBUG, agent:738] wan.OnEnter
2025-02-06 20:08:34.882, DEBUG, push:199] [push] new -> init
2025-02-06 20:08:34.882, DEBUG, push:199] [push] init -> ping
2025-02-06 20:08:34.883, DEBUG, agent:744] wan.msg: push:offline_notify
2025-02-06 20:08:34.883, DEBUG, msync:102] updateState: new -> init
2025-02-06 20:08:34.883, DEBUG, msync:102] updateState: init -> sleep
2025-02-06 20:08:40.906, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:08:45.906, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:08:50.907, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:08:55.906, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:09:00.906, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:09:01.194, DEBUG, ping:84] [ping] tag:push.ping, evt: recv
2025-02-06 20:09:01.195, DEBUG, ping:72] [ping] tag:push.ping, evt: stop
2025-02-06 20:09:01.195, DEBUG, ping:46] [ping] tag:push.ping, evt: close: false
2025-02-06 20:09:01.195, DEBUG, push:199] [push] ping -> connect
2025-02-06 20:09:01.195, DEBUG, push:409] addr:esimcontrol.eiotclub.com:1887
2025-02-06 20:09:01.595, DEBUG, push:243] send.len: 164
2025-02-06 20:09:01.597, DEBUG, push:262] runRead.enter
2025-02-06 20:09:01.834, DEBUG, push:199] [push] connect -> sync
2025-02-06 20:09:01.835, DEBUG, agent:744] wan.msg: push:online_notify
2025-02-06 20:09:01.835, DEBUG, msync:42] MsyncAct
2025-02-06 20:09:01.835, DEBUG, msync:124] [sleep] evt.Kind=msync:act
2025-02-06 20:09:01.836, DEBUG, msync:102] updateState: sleep -> sync
2025-02-06 20:09:01.836, DEBUG, progress:34] TransProgress.tryLock: in sync_req operation
2025-02-06 20:09:01.836, DEBUG, progress:42] TransProgress.lockOk: in sync_req operation
2025-02-06 20:09:02.467, DEBUG, ipa:126] IpaReopen
2025-02-06 20:09:03.468, DEBUG, ipa:162] tryOpen:0
Thu Feb 6 20:09:03 2025
Thu Feb 6 20:09:04 2025
2025-02-06 20:09:05.901, DEBUG, ipa:247] IpaGetProfileList
Thu Feb 6 20:09:05 2025
DBG, IPA_LIST_PROFILES, lib/esim/ipa2.c:727 [begin]
DBG, ES10C_LIST_PROFILE, lib/esim/es10.c:1188 [enter, iccid:]
Thu Feb 6 20:09:06 2025
DBG, ES10C_LIST_PROFILE, lib/esim/es10.c:1207 [exit, rcode:0]
2025-02-06 20:09:06.214, DEBUG, profile:170] table.trySave
2025-02-06 20:09:06.215, DEBUG, profile:170] table.trySave
2025-02-06 20:09:06.216, DEBUG, progress:52] TransProgress:Stop
2025-02-06 20:09:06.480, DEBUG, msync:283] [sync] evt.Kind=msync:req
2025-02-06 20:09:06.480, DEBUG, msync:288] retry.count:1
2025-02-06 20:09:06.481, DEBUG, agent:744] wan.msg: msync:req
2025-02-06 20:09:06.493, DEBUG, push:243] send.len: 516
2025-02-06 20:09:06.647, DEBUG, push:546] ignore.type:6
2025-02-06 20:09:06.657, DEBUG, push:307] recv.len:197
2025-02-06 20:09:06.659, DEBUG, agent:744] wan.msg: push:recv_msg
2025-02-06 20:09:06.676, DEBUG, msync:52] MsyncIdle
2025-02-06 20:09:06.676, DEBUG, agent:1306] sync_resp.OnEnter
2025-02-06 20:09:06.694, DEBUG, msync:283] [sync] evt.Kind=msync:idle
2025-02-06 20:09:06.704, DEBUG, msync:102] updateState: sync -> idle
2025-02-06 20:09:06.677, DEBUG, msync:333] MsyncHandleResp.begin:1738872546
2025-02-06 20:09:06.713, DEBUG, msync:351] no.update
2025-02-06 20:09:06.713, DEBUG, msync:352] MsyncHandleResp.end:1738872546
2025-02-06 20:09:06.715, DEBUG, agent:1325] sync_resp.msg: sync:end
2025-02-06 20:09:06.715, DEBUG, agent:1359] sync_resp.OnExit
2025-02-06 20:09:06.716, DEBUG, agent:819] wan.OnExit
2025-02-06 20:09:06.727, DEBUG, agent:738] wan.OnEnter
2025-02-06 20:09:06.728, DEBUG, push:29] push: already run
Thu Feb 6 20:12:43 2025
Thu Feb 6 20:12:44 2025
2025-02-06 20:12:54.422, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
2025-02-06 20:12:54.422, DEBUG, progress:42] TransProgress.lockOk: in sdk operation
2025-02-06 20:12:54.422, DEBUG, ipa:126] IpaReopen
2025-02-06 20:12:55.426, DEBUG, ipa:162] tryOpen:0
Thu Feb 6 20:12:55 2025
Thu Feb 6 20:12:56 2025
2025-02-06 20:12:57.280, DEBUG, ipa:247] IpaGetProfileList
Thu Feb 6 20:12:57 2025
2025-02-06 20:12:57.373, DEBUG, progress:52] TransProgress:Stop
2025-02-06 20:12:57.393, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
2025-02-06 20:12:57.394, DEBUG, progress:42] TransProgress.lockOk: in sdk operation
2025-02-06 20:12:57.394, DEBUG, ipa:126] IpaReopen
2025-02-06 20:12:57.395, DEBUG, ipa:149] reopen.ignore:3
2025-02-06 20:12:57.396, DEBUG, ipa:231] IpaGetEuiccInfo2
2025-02-06 20:12:57.557, DEBUG, progress:52] TransProgress:Stop
2025-02-06 20:14:03.184, DEBUG, push:546] ignore.type:4
2025-02-06 20:14:06.708, DEBUG, msync:102] updateState: idle -> sync
2025-02-06 20:14:06.708, DEBUG, progress:34] TransProgress.tryLock: in sync_req operation
2025-02-06 20:14:06.708, DEBUG, progress:42] TransProgress.lockOk: in sync_req operation
2025-02-06 20:14:07.008, DEBUG, ipa:126] IpaReopen
2025-02-06 20:14:08.008, DEBUG, ipa:162] tryOpen:0
Thu Feb 6 20:14:08 2025
2025-02-06 20:14:09.744, DEBUG, ipa:247] IpaGetProfileList
Thu Feb 6 20:14:09 2025
2025-02-06 20:14:09.863, DEBUG, progress:52] TransProgress:Stop
2025-02-06 20:14:09.922, DEBUG, msync:283] [sync] evt.Kind=msync:req
2025-02-06 20:14:09.923, DEBUG, msync:288] retry.count:1
2025-02-06 20:14:09.923, DEBUG, agent:744] wan.msg: msync:req
2025-02-06 20:14:09.924, DEBUG, push:243] send.len: 520
2025-02-06 20:14:10.081, DEBUG, push:546] ignore.type:6
2025-02-06 20:14:10.139, DEBUG, push:307] recv.len:197
2025-02-06 20:14:10.140, DEBUG, agent:744] wan.msg: push:recv_msg
2025-02-06 20:14:10.141, DEBUG, msync:52] MsyncIdle
2025-02-06 20:14:10.141, DEBUG, agent:1306] sync_resp.OnEnter
2025-02-06 20:14:10.142, DEBUG, msync:333] MsyncHandleResp.begin:1738872849
2025-02-06 20:14:10.142, DEBUG, msync:283] [sync] evt.Kind=msync:idle
2025-02-06 20:14:10.145, DEBUG, msync:102] updateState: sync -> idle
2025-02-06 20:14:10.146, DEBUG, msync:351] no.update
2025-02-06 20:14:10.146, DEBUG, msync:352] MsyncHandleResp.end:1738872849
2025-02-06 20:14:10.147, DEBUG, agent:1325] sync_resp.msg: sync:end
2025-02-06 20:14:10.152, DEBUG, agent:1359] sync_resp.OnExit
2025-02-06 20:14:10.158, DEBUG, agent:819] wan.OnExit
2025-02-06 20:14:10.159, DEBUG, agent:738] wan.OnEnter
2025-02-06 20:14:10.159, DEBUG, push:29] push: already run
2025-02-06 20:15:11.441, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
2025-02-06 20:15:11.441, DEBUG, progress:42] TransProgress.lockOk: in sdk operation
2025-02-06 20:15:11.442, DEBUG, ipa:126] IpaReopen
2025-02-06 20:15:12.442, DEBUG, ipa:162] tryOpen:0
Thu Feb 6 20:15:12 2025
2025-02-06 20:15:15.180, DEBUG, ipa:414] IpaProcessNotify
Thu Feb 6 20:15:15 2025
DBG, IPA_PROCESS_NOTIFY_A, lib/esim/ipa2.c:1165 [begin]
DBG, ES10C_LIST_PROFILE_0, lib/esim/es10.c:1469 [notify_type: F0]
Thu Feb 6 20:15:17 2025
DBG, PARSE_NOITFY_RESP_2, lib/esim/es10.c:1587 [tlv.ok: 196]
DBG, IPA_PROCESS_NOTIFY_1, lib/esim/ipa2.c:1189 [seq:8]
Thu Feb 6 20:15:18 2025
DBG, ES10B_REMOVE_NOTIFY_0, lib/esim/es10.c:1681 [seq: 8]
DBG, IPA_PROCESS_NOTIFY_B, lib/esim/ipa2.c:1225 [end]
2025-02-06 20:15:18.731, DEBUG, ipa:427] notify.ok
2025-02-06 20:15:18.732, DEBUG, ipa:126] IpaReopen
2025-02-06 20:15:19.733, DEBUG, ipa:162] tryOpen:0
Thu Feb 6 20:15:19 2025
Thu Feb 6 20:15:20 2025
2025-02-06 20:15:21.097, DEBUG, ipa:296] IpaDownloadInstall
2025-02-06 20:15:21.098, DEBUG, ipa:320] download rsp: [mass.prod.ondemandconnectivity.com], matchingId: [7TGG57O1NXZM8LWHIC1ETA7CEOCNQEY0CSZZSCKR98RJFA8UVA9NFCZHAK1G71HQ], confirmCode:
Thu Feb 6 20:15:21 2025
DBG, IPA_DL_RETRY, lib/esim/ipa2.c:1148 [retry:0]
DBG, IPA_DL_0, lib/esim/ipa2.c:949 [es10.euicc_info1]
DBG, IPA_DL_1, lib/esim/ipa2.c:957 [es10.euicc_challenge]
DBG, IPA_DL_2, lib/esim/ipa2.c:965 [es9.init_auth]
Thu Feb 6 20:15:22 2025
DBG, IPA_DL_3, lib/esim/ipa2.c:988 [es10.auth_server]
Thu Feb 6 20:15:28 2025
DBG, IPA_DL_4, lib/esim/ipa2.c:1010 [es9.auth_client]
Thu Feb 6 20:15:29 2025
DBG, IPA_DL_5, lib/esim/ipa2.c:1030 [es10.prepare_dl]
Thu Feb 6 20:15:33 2025
DBG, IPA_DL_6, lib/esim/ipa2.c:1059 [es9.get_bpp]
Thu Feb 6 20:15:35 2025
DBG, ES9_GET_BPP_0, lib/esim/es9.c:414 [get.end: 0]
DBG, ES9_GET_BPP_1, lib/esim/es9.c:424 [json.ok]
DBG, ES9_GET_BPP_2, lib/esim/es9.c:435 [transaction.ok]
DBG, ES9_GET_BPP_3, lib/esim/es9.c:443 [package:75396]
DBG, IPA_DL_6_1, lib/esim/ipa2.c:1071 [es9.get_bpp_ok]
DBG, IPA_DL_7, lib/esim/ipa2.c:1080 [gen_sbpp]
DBG, BPP_GEN_SBPP_6, lib/esim/bpp.c:158 [ok]
DBG, IPA_DL_7_1, lib/esim/ipa2.c:1088 [gen_sbpp_ok]
DBG, IPA_DL_8, lib/esim/ipa2.c:1096 [es10.load_bpp]
Thu Feb 6 20:16:48 2025
ERR, CHECK_INSTALL_RESULT, lib/esim/es10.c:753 [err: 12]
Thu Feb 6 20:16:52 2025
DBG, IPA_SEND_APDU, lib/esim/ipa2.c:485 [invalid.resp:6982]
Thu Feb 6 20:16:55 2025
Thu Feb 6 20:16:59 2025
Thu Feb 6 20:17:04 2025
Thu Feb 6 20:17:10 2025
Thu Feb 6 20:17:17 2025
Thu Feb 6 20:17:20 2025
Thu Feb 6 20:17:24 2025
Thu Feb 6 20:17:29 2025
Thu Feb 6 20:17:35 2025
Thu Feb 6 20:17:43 2025
Thu Feb 6 20:17:46 2025
Thu Feb 6 20:17:50 2025
Thu Feb 6 20:17:55 2025
Thu Feb 6 20:18:01 2025
Thu Feb 6 20:18:09 2025
Thu Feb 6 20:18:12 2025
Thu Feb 6 20:18:16 2025
Thu Feb 6 20:18:21 2025
Thu Feb 6 20:18:27 2025
Thu Feb 6 20:18:35 2025
Thu Feb 6 20:18:38 2025
Thu Feb 6 20:18:42 2025
Thu Feb 6 20:18:47 2025
2025-02-06 20:18:50.966, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
Thu Feb 6 20:18:53 2025
Thu Feb 6 20:19:01 2025
2025-02-06 20:19:03.173, DEBUG, push:546] ignore.type:4
Thu Feb 6 20:19:04 2025
2025-02-06 20:19:05.972, DEBUG, sdk:198] wait.overtime: in sdk operation
Thu Feb 6 20:19:08 2025
2025-02-06 20:19:10.145, DEBUG, msync:102] updateState: idle -> sync
2025-02-06 20:19:10.146, DEBUG, progress:34] TransProgress.tryLock: in sync_req operation
Thu Feb 6 20:19:13 2025
Thu Feb 6 20:19:19 2025
Thu Feb 6 20:19:26 2025
Thu Feb 6 20:19:30 2025
2025-02-06 20:19:30.382, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
Thu Feb 6 20:19:34 2025
Thu Feb 6 20:19:39 2025
Thu Feb 6 20:19:45 2025
2025-02-06 20:19:45.390, DEBUG, sdk:198] wait.overtime: in sdk operation
Thu Feb 6 20:19:52 2025
Thu Feb 6 20:19:55 2025
Thu Feb 6 20:19:59 2025
Thu Feb 6 20:20:04 2025
Thu Feb 6 20:20:10 2025
Thu Feb 6 20:20:19 2025
Thu Feb 6 20:20:22 2025
Thu Feb 6 20:20:26 2025
Thu Feb 6 20:20:31 2025
Thu Feb 6 20:20:37 2025
Thu Feb 6 20:20:44 2025
Thu Feb 6 20:20:47 2025
Thu Feb 6 20:20:51 2025
Thu Feb 6 20:20:57 2025
Thu Feb 6 20:21:03 2025
Thu Feb 6 20:21:10 2025
2025-02-06 20:21:11.562, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
Thu Feb 6 20:21:13 2025
Thu Feb 6 20:21:17 2025
Thu Feb 6 20:21:22 2025
2025-02-06 20:21:26.569, DEBUG, sdk:198] wait.overtime: in sdk operation
Thu Feb 6 20:21:29 2025
Thu Feb 6 20:21:36 2025
2025-02-06 20:21:37.755, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
Thu Feb 6 20:21:39 2025
2025-02-06 20:21:40.173, DEBUG, msync:181] wait.overtime: in sdk operation
2025-02-06 20:21:40.173, DEBUG, msync:102] updateState: sync -> idle
Thu Feb 6 20:21:43 2025
Thu Feb 6 20:21:48 2025
2025-02-06 20:21:52.769, DEBUG, sdk:198] wait.overtime: in sdk operation
Thu Feb 6 20:21:54 2025
Thu Feb 6 20:22:02 2025
Thu Feb 6 20:22:05 2025
Thu Feb 6 20:22:09 2025
Thu Feb 6 20:22:14 2025
Thu Feb 6 20:22:20 2025
Thu Feb 6 20:22:29 2025
2025-02-06 20:22:31.952, ERROR, ping:113] exit status 1
2025-02-06 20:22:31.952, DEBUG, push:514] ping.fail.1
Thu Feb 6 20:22:32 2025
2025-02-06 20:24:23.642, DEBUG, main:31] lpaVer:1.47@owt.mips, debugOn:false, atMode:ubus, syncMode:on, mdReboot:5, seedAuto:false, delNotify:true
2025-02-06 20:24:23.661, DEBUG, main:34] config
2025-02-06 20:24:23.670, ERROR, config:57] open /root/esim/conf.json: no such file or directory
2025-02-06 20:24:23.670, DEBUG, main:38] db
2025-02-06 20:24:23.671, DEBUG, main:42] http
2025-02-06 20:24:23.671, DEBUG, main:46] at
2025-02-06 20:24:23.687, DEBUG, at:390] initAtServiceUbus
2025-02-06 20:24:23.692, DEBUG, main:54] ipa
2025-02-06 20:24:23.694, DEBUG, ipa:91] InitIpa
Thu Feb 6 20:24:23 2025
2025-02-06 20:24:23.697, DEBUG, main:63] agent
2025-02-06 20:24:23.697, DEBUG, main:70] idle
2025-02-06 20:24:23.698, DEBUG, main:79] clean.log
2025-02-06 20:24:23.693, DEBUG, at:87] UbusAtService.run
2025-02-06 20:24:23.720, DEBUG, agent:346] default.OnEnter
2025-02-06 20:24:23.729, DEBUG, agent:351] default.msg: default:next
2025-02-06 20:24:23.784, DEBUG, agent:429] wakeup.OnEnter
2025-02-06 20:24:23.785, DEBUG, agent:435] wakeup.msg: wakeup:next
2025-02-06 20:24:23.937, DEBUG, agent:529] ready.OnEnter
2025-02-06 20:24:23.937, DEBUG, agent:537] ready.msg: ready:next
Thu Feb 6 20:24:24 2025
2025-02-06 20:24:24.905, DEBUG, agent:641] esim.OnEnter
2025-02-06 20:24:24.905, DEBUG, agent:651] esim.msg: esim:next
2025-02-06 20:24:24.905, DEBUG, agent:657] seed.auto: false
2025-02-06 20:24:24.906, DEBUG, agent:738] wan.OnEnter
2025-02-06 20:24:24.906, DEBUG, push:199] [push] new -> init
2025-02-06 20:24:24.906, DEBUG, push:199] [push] init -> ping
2025-02-06 20:24:24.907, DEBUG, agent:744] wan.msg: push:offline_notify
2025-02-06 20:24:24.907, DEBUG, msync:102] updateState: new -> init
2025-02-06 20:24:24.907, DEBUG, msync:102] updateState: init -> sleep
2025-02-06 20:24:30.847, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:24:35.845, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:24:40.901, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:24:45.846, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:24:50.845, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:24:55.864, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:26:11.262, DEBUG, push:373] ignore.evt:ping:idle
2025-02-06 20:26:11.378, DEBUG, ping:84] [ping] tag:push.ping, evt: recv
2025-02-06 20:26:11.379, DEBUG, ping:72] [ping] tag:push.ping, evt: stop
2025-02-06 20:26:11.379, DEBUG, ping:46] [ping] tag:push.ping, evt: close: false
2025-02-06 20:26:11.379, DEBUG, push:199] [push] ping -> connect
2025-02-06 20:26:11.379, DEBUG, push:409] addr:esimcontrol.eiotclub.com:1887
2025-02-06 20:26:11.740, DEBUG, push:243] send.len: 164
2025-02-06 20:26:11.741, DEBUG, push:262] runRead.enter
2025-02-06 20:26:12.015, DEBUG, push:199] [push] connect -> sync
2025-02-06 20:26:12.015, DEBUG, agent:744] wan.msg: push:online_notify
2025-02-06 20:26:12.016, DEBUG, msync:42] MsyncAct
2025-02-06 20:26:12.016, DEBUG, msync:124] [sleep] evt.Kind=msync:act
2025-02-06 20:26:12.016, DEBUG, msync:102] updateState: sleep -> sync
2025-02-06 20:26:12.017, DEBUG, progress:34] TransProgress.tryLock: in sync_req operation
2025-02-06 20:26:12.017, DEBUG, progress:42] TransProgress.lockOk: in sync_req operation
2025-02-06 20:26:12.499, DEBUG, ipa:126] IpaReopen
2025-02-06 20:26:13.500, DEBUG, ipa:162] tryOpen:0
Thu Feb 6 20:26:13 2025
Thu Feb 6 20:26:14 2025
2025-02-06 20:26:15.294, DEBUG, ipa:247] IpaGetProfileList
Thu Feb 6 20:26:15 2025
2025-02-06 20:26:15.458, DEBUG, progress:52] TransProgress:Stop
2025-02-06 20:26:15.566, DEBUG, msync:283] [sync] evt.Kind=msync:req
2025-02-06 20:26:15.566, DEBUG, msync:288] retry.count:1
2025-02-06 20:26:15.567, DEBUG, agent:744] wan.msg: msync:req
2025-02-06 20:26:15.594, DEBUG, push:243] send.len: 400
2025-02-06 20:26:15.706, DEBUG, push:546] ignore.type:6
2025-02-06 20:26:15.724, DEBUG, push:307] recv.len:197
2025-02-06 20:26:15.725, DEBUG, agent:744] wan.msg: push:recv_msg
2025-02-06 20:26:15.728, DEBUG, msync:52] MsyncIdle
2025-02-06 20:26:15.728, DEBUG, agent:1306] sync_resp.OnEnter
2025-02-06 20:26:15.729, DEBUG, msync:333] MsyncHandleResp.begin:1738873575
2025-02-06 20:26:15.729, DEBUG, msync:351] no.update
2025-02-06 20:26:15.730, DEBUG, msync:352] MsyncHandleResp.end:1738873575
2025-02-06 20:26:15.753, DEBUG, msync:283] [sync] evt.Kind=msync:idle
2025-02-06 20:26:15.754, DEBUG, msync:102] updateState: sync -> idle
2025-02-06 20:26:15.730, DEBUG, agent:1325] sync_resp.msg: sync:end
2025-02-06 20:26:15.754, DEBUG, agent:1359] sync_resp.OnExit
2025-02-06 20:26:15.754, DEBUG, agent:819] wan.OnExit
2025-02-06 20:26:15.755, DEBUG, agent:738] wan.OnEnter
2025-02-06 20:26:15.755, DEBUG, push:29] push: already run
Thu Feb 6 20:26:44 2025
Thu Feb 6 20:26:45 2025
2025-02-06 20:27:08.240, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
2025-02-06 20:27:08.240, DEBUG, progress:42] TransProgress.lockOk: in sdk operation
2025-02-06 20:27:08.241, DEBUG, ipa:126] IpaReopen
2025-02-06 20:27:09.242, DEBUG, ipa:162] tryOpen:0
Thu Feb 6 20:27:09 2025
2025-02-06 20:27:10.708, DEBUG, ipa:247] IpaGetProfileList
Thu Feb 6 20:27:10 2025
2025-02-06 20:27:10.805, DEBUG, progress:52] TransProgress:Stop
2025-02-06 20:27:10.824, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
2025-02-06 20:27:10.824, DEBUG, progress:42] TransProgress.lockOk: in sdk operation
2025-02-06 20:27:10.831, DEBUG, ipa:126] IpaReopen
2025-02-06 20:27:10.831, DEBUG, ipa:149] reopen.ignore:2
2025-02-06 20:27:10.831, DEBUG, ipa:231] IpaGetEuiccInfo2
2025-02-06 20:27:10.984, DEBUG, progress:52] TransProgress:Stop
2025-02-06 20:27:35.228, DEBUG, progress:34] TransProgress.tryLock: in sdk operation
2025-02-06 20:27:35.228, DEBUG, progress:42] TransProgress.lockOk: in sdk operation
2025-02-06 20:27:35.228, DEBUG, ipa:126] IpaReopen
2025-02-06 20:27:35.229, DEBUG, ipa:149] reopen.ignore:27
2025-02-06 20:27:36.406, DEBUG, ipa:414] IpaProcessNotify
I have now downloaded and installed the Beta firmware and switched to a Lyca mobile esim
This has installed and is working correctly.
Can only assume the issue was with the previous esim itself.
Thanks for your reply Bruce :+1:
Hi @untoldfattboy, it seems that the router and esim service are not compatible, the router cannot communicate with the esim server, so the esim installation fails.
You are sure the Lyca mobile esim works properly, right? We will record it. FYI, here is a list of supported esim services, please see it for more details if required.
Thankyou for the list.
Yes the Lycamobile esim is working perfectly.
I signed up to the £2.50 first month then £5 for 5GB as I didn't want to spend too much testing out the physical esim card.
I am currently running the beta firmware with no issues if that makes any difference.
