Not sure why. Seemed to be working fine, but will not connect. I am able to connect with my comps (while on main network), but will not enable on the router.
Log:
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: TCP connection established with [AF_INET]185.203.218.150:443
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: TCP_CLIENT link local: (not bound)
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: TCP_CLIENT link remote: [AF_INET]185.203.218.150:443
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: TLS: Initial packet from [AF_INET]185.203.218.150:443, sid=d3d19f7c da91984c
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA8
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: VERIFY KU OK
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: Validating certificate extended key usage
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: VERIFY EKU OK
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: VERIFY X509NAME OK: CN=us9395.nordvpn.com
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: VERIFY OK: depth=0, CN=us9395.nordvpn.com
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512
Wed Jun 28 10:55:18 2023 daemon.notice ovpnclient[5317]: [us9395.nordvpn.com] Peer Connection Initiated with [AF_INET]185.203.218.150:443
Wed Jun 28 10:55:19 2023 daemon.notice ovpnclient[5317]: SENT CONTROL [us9395.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)
Wed Jun 28 10:55:24 2023 daemon.notice ovpnclient[5317]: SENT CONTROL [us9395.nordvpn.com]: ‘PUSH_REQUEST’ (status=1)
Wed Jun 28 10:55:24 2023 daemon.notice ovpnclient[5317]: AUTH: Received control message: AUTH_FAILED
Wed Jun 28 10:55:24 2023 daemon.notice ovpnclient[5317]: SIGTERM[soft,auth-failure] received, process exiting
Wed Jun 28 10:55:29 2023 daemon.notice netifd: Interface ‘ovpnclient’ is now down
Wed Jun 28 10:55:29 2023 daemon.notice netifd: Interface ‘ovpnclient’ is setting up now
