Hello there;
What is the proper way to update Adguard that is part of your MT6000 Flint2 Router?
I have tried a couple different ways, each time I had to Flash my router to get Adguard working again.
Which of course it flashes back to the original
I really do not want to keep flashing my router.
My Router firmware version v4.5.6
My Adguard Version v0.107.26
Upgrading it from within the plugin app breaks it.
I also tried to upgrade it from using WinSCP and getting it from Github
Using AdGuardHomeLinux arm64.tar.gz
It was already broken I tring diiferent things and not really knowing whatI was doing.
Do you have clear instruction on how to update and/or which file to use to update if the Plugg-in app inside the router does not work?
Thank you.
