USB wireless antenna stopped working
The router is a Brume and the antenna is a TP-Link Archer T2 Plus.
Wi-fi has been working nicely for a long time, and for some reason has stopped working.
Wireless Overview reads
Generic 802.11 Wireless Controller
Channel: ? (? GHz) | Bitrate: ? Mbit/s
and when a network is enabled, it reads
Wireless is not associated
What are the things to check now?
you can unplug and replug the wifi dongle and check if it works.
Then get the log by ssh to the router and using the following command
logread
dmesg
Sun Jan 3 09:09:56 2021 kern.info kernel: [311527.097283] usb 1-1: USB disconnect, device number 3
Sun Jan 3 09:10:01 2021 kern.info kernel: [311531.237258] usb 1-1: new high-speed USB device number 4 using orion-ehci
from logread
from dmesg
opkg tells me nothing is upgradable if that helps
Update: plugged the TP-Link dongle into a windows pc and it worked nicely.
The LED on the antenna doesn’t blink when plugged into the Brume.
It does seem like the USB hubs on Brume are working ok, since the logs know the dongle is being plugged in.
From the log, it dongle is not supported.
USB hubs generally do not need a extra driver to work.
The dongle had support added by this .ipk file, has it been dropped since?
Thu Jan 7 10:40:24 2021 kern.info kernel: [ 931.038024] usb 1-1: USB disconnect, device number 2
Thu Jan 7 10:40:26 2021 kern.info kernel: [ 932.366614] usb 1-1: new high-speed USB device number 3 using orion-ehci
Thu Jan 7 10:40:39 2021 daemon.notice netifd: radio0 (11242): sh: out of range
Thu Jan 7 10:40:40 2021 daemon.notice netifd: radio0 (11242): command failed: No such device (-19)
Thu Jan 7 10:40:40 2021 user.notice mac80211: Failed command: iw phy phy2 interface add wlan0 type __ap
Thu Jan 7 10:40:40 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy2.conf
Thu Jan 7 10:40:40 2021 daemon.err hostapd: Line 33: invalid SSID ‘’
Thu Jan 7 10:40:40 2021 daemon.err hostapd: 1 errors found in configuration file ‘/var/run/hostapd-phy2.conf’
Thu Jan 7 10:40:40 2021 daemon.err hostapd: Failed to set up interface with /var/run/hostapd-phy2.conf
Thu Jan 7 10:40:40 2021 daemon.err hostapd: Failed to initialize interface
Thu Jan 7 10:40:40 2021 daemon.notice netifd: radio0 (11242): cat: can’t open ‘/var/run/wifi-phy2.pid’: No such file or directory
Thu Jan 7 10:40:40 2021 daemon.notice netifd: radio0 (11242): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process path (/proc/exe)
Thu Jan 7 10:40:40 2021 daemon.notice netifd: radio0 (11242): Command failed: Invalid argument
Thu Jan 7 10:40:40 2021 daemon.notice netifd: radio0 (11242): Device setup failed: HOSTAPD_START_FAILED
Thu Jan 7 10:40:45 2021 kern.info kernel: [ 951.557911] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
I opkg installed the ipk again and re-plugged the dongle. logread has more errors now.
I’ve had no wi-fi for half a month now, any ideas?
If you are using multiple wireless interfaces, you can check that working by leaving one and disabling it.
Also, the transmission may be restricted even with a combination of non-interfering channels, so only use 1, 6, 11 be preferred for 2.4GHz.
