I have been using a Huaweii 4G stick as a failover 2nd internet connection on my home router for years.
The stick has died.
I also have a GL-XE300C4 4G WIFI router which works really well. I take this on holidays to provide family internet.
Can I use this as my failover device plugged into the checkpoint router?
I don’t want double NAT, so I would need to somehow turn the GL XE300 into just a dumb 4g modem sending a WAN link out one of its ethernet ports and let the checkpoint handle all the routing.
Turning it to AP mode doesn’t seem to work, as this makes it behave like an access point NOT a bridge, which I think is what I want.
So how to turn this wonderful device into a 4G modem ONLY, so I can use it as my 2nd internet connection on my main home router.
I am not sure if I can/how I can configure this.
Any help much appreciated.
Hello
thankyou for writing back
The only advantage in using the XE300 as a 4G modem only is that I already own this device, and I d not have to go and buy something new.
The XE300 is an excellent modem and an excellent router.
I use it when I go on holiday all the time with a local SIM card.
But my main router at home is a higher end checkpoint router firewall.
It supports dual WAN. I use Fibre and 4G as backup.
Previously I used a USB 4G dongle, but that has died, so I thought I could use the XE300 and therefore I would not have to buy a new device.
IP Passthrough is exacrtly what I am after!!
The main router gets the Public IP address, and the XE300 functions only as a “dumb” modem.
If it is easy to implement I think it would be a good feature to add.
I am also happy to make some changes via the Luci interface if you can tell me what to do.
Hi @dbanyasz and @Fovty , I have talked with our R&D team, we willl compile a test firmware what add IP Passthrogh function for you in next week, you can test it, thank you for your feedback.
@Hoff If possible, I would appreciate testing this build as well. I am beta testing the XE3000 starting the 8th and having a 2nd portable modem for failover, load balancing, etc, would be helpful.
@Sskanse@GFH_1234@Fovty Can you tell me why you need use this funcution and your application scenarios? please follow this attachment document to share your device to my account via GL.iNet cloud, and send your device mac address and password to my email([email protected]).
I will add this function on your firmware, this function isn’t released, so this function just be tested on a small scale. Share the device to technical support via Goodcloud.zip (206.0 KB)
Can you give me more information or your home internet topology ? As we know, most of home have a main router with one WAN port, this router use this WAN port to connect carrier internet use ethernet cable or optical fiber, there isn’t another WAN port to connect our router LAN port. Why do you need to use IP Passthrough function? and how to connect our router?
Thank you for your information!
Exactly as you described. Main router is third party router (mesh system). I want to drop in X3000 with a SIM card to replace internet modem, without touching existing main router.
