More information, from my Linux laptop (it’s long, so also attached to the post).
wanmodem-syslog.zip (3.7 KB)
Feb 11 14:44:28 xps-9320 kernel: [102464.303131][T42197] usb 3-1: new high-speed USB device number 30 using xhci_hcd
Feb 11 14:44:28 xps-9320 kernel: [102464.492203][T42197] usb 3-1: config 1 has an invalid interface number: 9 but max is
0
Feb 11 14:44:28 xps-9320 kernel: [102464.492212][T42197] usb 3-1: config 1 has no interface number 0
Feb 11 14:44:28 xps-9320 kernel: [102464.492712][T42197] usb 3-1: config 2 has an invalid interface number: 12 but max i
s 1
Feb 11 14:44:28 xps-9320 kernel: [102464.492720][T42197] usb 3-1: config 2 has an invalid interface number: 13 but max i
s 1
Feb 11 14:44:28 xps-9320 kernel: [102464.492722][T42197] usb 3-1: config 2 has an invalid interface number: 13 but max i
s 1
Feb 11 14:44:28 xps-9320 kernel: [102464.492725][T42197] usb 3-1: config 2 has no interface number 0
Feb 11 14:44:28 xps-9320 kernel: [102464.492727][T42197] usb 3-1: config 2 has no interface number 1
Feb 11 14:44:28 xps-9320 kernel: [102464.493564][T42197] usb 3-1: New USB device found, idVendor=1199, idProduct=0fff, bcdDevice= 0.06
Feb 11 14:44:28 xps-9320 kernel: [102464.493575][T42197] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 11 14:44:28 xps-9320 kernel: [102464.493579][T42197] usb 3-1: Product: AirCard 340U
Feb 11 14:44:28 xps-9320 kernel: [102464.493582][T42197] usb 3-1: Manufacturer: Sierra Wireless, Incorporated
Feb 11 14:44:28 xps-9320 kernel: [102464.493584][T42197] usb 3-1: SerialNumber: 013323002658699
Feb 11 14:44:28 xps-9320 kernel: [102464.496836][T42197] usb-storage 3-1:1.9: USB Mass Storage device detected
Feb 11 14:44:28 xps-9320 kernel: [102464.510292][T42197] usb-storage: probe of 3-1:1.9 failed with error -5
Feb 11 14:44:28 xps-9320 mtp-probe: checking bus 3, device 30: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Feb 11 14:44:28 xps-9320 mtp-probe: bus: 3, device: 30 was not an MTP device
Feb 11 14:44:28 xps-9320 systemd[1]: Created slice Slice /system/usb_modeswitch.
Feb 11 14:44:28 xps-9320 systemd[1]: Starting USB_ModeSwitch_3-1...
Feb 11 14:44:29 xps-9320 mtp-probe: checking bus 3, device 30: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Feb 11 14:44:29 xps-9320 mtp-probe: bus: 3, device: 30 was not an MTP device
Feb 11 14:44:29 xps-9320 usb_modeswitch: switch device 1199:0fff on 003/030
Feb 11 14:44:29 xps-9320 kernel: [102465.201357][T46904] usb-storage 3-1:2.12: USB Mass Storage device detected
Feb 11 14:44:29 xps-9320 kernel: [102465.205606][T46857] usbcore: registered new interface driver cdc_ncm
Feb 11 14:44:29 xps-9320 vmnetBridge: RTM_NEWLINK: name:wwan0 index:16 flags:0x00001082
Feb 11 14:44:29 xps-9320 kernel: [102465.240499][T46904] cdc_mbim 3-1:2.12: cdc-wdm2: USB WDM device
Feb 11 14:44:29 xps-9320 kernel: [102465.240674][T46904] cdc_mbim 3-1:2.12 wwan0: register 'cdc_mbim' at usb-0000:00:14.0-1, CDC MBIM, 5a:ef:47:f4:47:2c
Feb 11 14:44:29 xps-9320 kernel: [102465.240951][T46857] usbcore: registered new interface driver cdc_mbim
Feb 11 14:44:29 xps-9320 systemd-udevd[46916]: Using default interface naming scheme 'v249'.
Feb 11 14:44:30 xps-9320 root: usb_modeswitch: switched to 1199:0fff on 003/030
Feb 11 14:44:31 xps-9320 systemd[1]: usb_modeswitch@3-1.service: Deactivated successfully.
Feb 11 14:44:31 xps-9320 systemd[1]: Finished USB_ModeSwitch_3-1.
Feb 11 14:44:31 xps-9320 ModemManager[1166]: opening device...
Feb 11 14:44:31 xps-9320 ModemManager[1166]: cannot connect to proxy: Could not connect: Connection refused
Feb 11 14:44:31 xps-9320 ModemManager[1166]: spawning new mbim-proxy (try 1)...
Feb 11 14:44:31 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Read max control message size from descriptors file: 4096
Feb 11 14:44:31 xps-9320 ModemManager[1166]: <info> [cdc-wdm2/mbim] MBIM device is not QMI capable
Feb 11 14:44:31 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] channel destroyed
Feb 11 14:44:31 xps-9320 kernel: [102467.573370][T42197] usb 3-1: USB disconnect, device number 30
Feb 11 14:44:31 xps-9320 kernel: [102467.573599][T42197] cdc_mbim 3-1:2.12 wwan0: unregister 'cdc_mbim' usb-0000:00:14.0-1, CDC MBIM
Feb 11 14:44:31 xps-9320 vmnetBridge: RTM_DELLINK: name:wwan0 index:16 flags:0x00001082
Feb 11 14:44:31 xps-9320 ModemManager[1166]: <info> [base-manager] port wwan0 released by device '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1'
Feb 11 14:44:31 xps-9320 ModemManager[1166]: <info> [base-manager] port cdc-wdm2 released by device '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1'
Feb 11 14:44:31 xps-9320 ModemManager[1166]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1': Operation was cancelled
Feb 11 14:44:32 xps-9320 kernel: [102468.169010][T42197] usb 3-1: new high-speed USB device number 31 using xhci_hcd
Feb 11 14:44:32 xps-9320 kernel: [102468.561662][T42197] usb 3-1: config 1 has an invalid interface number: 8 but max is
3
Feb 11 14:44:32 xps-9320 kernel: [102468.561673][T42197] usb 3-1: config 1 has no interface number 1
Feb 11 14:44:32 xps-9320 kernel: [102468.562197][T42197] usb 3-1: config 2 has an invalid interface number: 12 but max is 2
Feb 11 14:44:32 xps-9320 kernel: [102468.562207][T42197] usb 3-1: config 2 has an invalid interface number: 13 but max is 2
Feb 11 14:44:32 xps-9320 kernel: [102468.562209][T42197] usb 3-1: config 2 has an invalid interface number: 13 but max is 2
Feb 11 14:44:32 xps-9320 kernel: [102468.562212][T42197] usb 3-1: config 2 has an invalid interface number: 9 but max is 2
Feb 11 14:44:32 xps-9320 kernel: [102468.562215][T42197] usb 3-1: config 2 has no interface number 0
Feb 11 14:44:32 xps-9320 kernel: [102468.562217][T42197] usb 3-1: config 2 has no interface number 1
Feb 11 14:44:32 xps-9320 kernel: [102468.562219][T42197] usb 3-1: config 2 has no interface number 2
Feb 11 14:44:32 xps-9320 kernel: [102468.563027][T42197] usb 3-1: New USB device found, idVendor=1199, idProduct=9051, bcdDevice= 0.06
Feb 11 14:44:32 xps-9320 kernel: [102468.563038][T42197] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 11 14:44:32 xps-9320 kernel: [102468.563042][T42197] usb 3-1: Product: AirCard 340U
Feb 11 14:44:32 xps-9320 kernel: [102468.563045][T42197] usb 3-1: Manufacturer: Sierra Wireless, Incorporated
Feb 11 14:44:32 xps-9320 kernel: [102468.563047][T42197] usb 3-1: SerialNumber: 013323002658699
Feb 11 14:44:32 xps-9320 kernel: [102468.590752][T42197] cdc_mbim 3-1:2.12: cdc-wdm2: USB WDM device
Feb 11 14:44:32 xps-9320 kernel: [102468.591015][T42197] cdc_mbim 3-1:2.12 wwan0: register 'cdc_mbim' at usb-0000:00:14.0-1, CDC MBIM, 5a:ef:47:f4:47:2c
Feb 11 14:44:32 xps-9320 kernel: [102468.592002][T42197] usb-storage 3-1:2.9: USB Mass Storage device detected
Feb 11 14:44:32 xps-9320 vmnetBridge: RTM_NEWLINK: name:wwan0 index:17 flags:0x00001082
Feb 11 14:44:32 xps-9320 kernel: [102468.592495][T42197] scsi host2: usb-storage 3-1:2.9
Feb 11 14:44:32 xps-9320 mtp-probe: checking bus 3, device 31: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Feb 11 14:44:32 xps-9320 mtp-probe: bus: 3, device: 31 was not an MTP device
Feb 11 14:44:32 xps-9320 systemd[1]: Starting USB_ModeSwitch_3-1...
Feb 11 14:44:33 xps-9320 NetworkManager[1080]: <info> [1676155473.0655] audit: op="statistics" interface="eth0" ifindex=15 args="2000" pid=2902 uid=1000 result="success"
Feb 11 14:44:33 xps-9320 NetworkManager[1080]: <info> [1676155473.0746] audit: op="statistics" interface="wlan0" ifindex=7 args="2000" pid=2902 uid=1000 result="success"
Feb 11 14:44:33 xps-9320 usb_modeswitch: switch device 1199:9051 on 003/031
Feb 11 14:44:33 xps-9320 systemd-udevd[46857]: Using default interface naming scheme 'v249'.
Feb 11 14:44:33 xps-9320 systemd[1]: usb_modeswitch@3-1.service: Deactivated successfully.
Feb 11 14:44:33 xps-9320 systemd[1]: Finished USB_ModeSwitch_3-1.
Feb 11 14:44:33 xps-9320 mtp-probe: checking bus 3, device 31: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Feb 11 14:44:33 xps-9320 mtp-probe: bus: 3, device: 31 was not an MTP device
Feb 11 14:44:33 xps-9320 kernel: [102469.657351][T44634] scsi 2:0:0:0: Direct-Access Aircard Disk Drive 1.00 PQ: 0 ANSI: 2
Feb 11 14:44:33 xps-9320 kernel: [102469.657907][T44634] sd 2:0:0:0: Attached scsi generic sg1 type 0
Feb 11 14:44:33 xps-9320 kernel: [102469.659066][T46938] sd 2:0:0:0: Power-on or device reset occurred
Feb 11 14:44:33 xps-9320 kernel: [102469.659711][T44646] sd 2:0:0:0: [sdc] Media removed, stopped polling
Feb 11 14:44:33 xps-9320 kernel: [102469.660363][T44646] sd 2:0:0:0: [sdc] Attached SCSI removable disk
Feb 11 14:44:34 xps-9320 systemd-udevd[46914]: sdc: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/sdc' failed with exit code 1.
Feb 11 14:44:34 xps-9320 ModemManager[1166]: opening device...
Feb 11 14:44:34 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Read max control message size from descriptors file: 4096
Feb 11 14:44:35 xps-9320 ModemManager[1166]: <info> [cdc-wdm2/mbim] MBIM device is not QMI capable
Feb 11 14:44:35 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] channel destroyed
Feb 11 14:44:35 xps-9320 ModemManager[1166]: <info> [device /sys/devices/pci0000:00/0000:00:14.0/usb3/3-1] creating modem with plugin 'sierra' and '2' ports
Feb 11 14:44:35 xps-9320 ModemManager[1166]: <info> [base-manager] modem for device '/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1' successfully created
Feb 11 14:44:35 xps-9320 ModemManager[1166]: opening device...
Feb 11 14:44:35 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Read max control message size from descriptors file: 4096
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Opening device with flags 'version-info, proxy, mbim, expect-indications'...
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] created endpoint
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] creating MBIM device...
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] MBIM device created
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] opening MBIM device...
Feb 11 14:44:36 xps-9320 ModemManager[1166]: opening device...
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Read max control message size from descriptors file: 4096
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] MBIM device open
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Checking version info (15 retries)...
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] QMI Device supports 22 services:
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] ctl (1.5)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] wds (1.16)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] dms (1.13)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] nas (1.25)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] qos (1.3)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] wms (1.8)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] pds (1.13)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] auth (1.2)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] at (1.2)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] voice (2.1)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] cat2 (2.11)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] uim (1.12)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] pbm (1.4)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] loc (2.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] sar (1.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] ims (1.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] ts (1.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] tmd (1.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] wda (1.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] csvt (1.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] cat (2.11)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] unknown [0xf0] (1.0)
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Enabling QMI indications via MBIM...
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] enabled QMI indications via MBIM
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <info> [modem0/cdc-wdm2/mbim] MBIM device is QMI capable
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Allocating new client ID...
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Registered 'dms' (version 1.13) client with ID '3'
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Registered 'nas' (version 1.25) client with ID '3'
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Registered 'pds' (version 1.13) client with ID '1'
Feb 11 14:44:36 xps-9320 ModemManager[1166]: [/dev/cdc-wdm2] Registered 'loc' (version 2.0) client with ID '1'
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <info> [modem0] QMI-based capability and mode switching support enabled
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <warn> [modem0] couldn't load carrier config: QMI PDC not supported
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <warn> [modem0] couldn't query SIM slots: NoDeviceSupport
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <warn> [modem0/sim0] couldn't load list of emergency numbers: No AT port available to run command
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <warn> [modem0/sim0] couldn't load list of preferred networks: No AT port available to run command
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <warn> [modem0] couldn't load UE mode of operation for EPS: No AT port available to run command
Feb 11 14:44:36 xps-9320 ModemManager[1166]: <warn> [modem0] couldn't load initial EPS bearer settings: LTE attach status info is unsupported
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <warn> [modem0] couldn't load supported assistance data types: QMI protocol error (5): 'ClientIdsExhausted'
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <warn> [modem0] couldn't open ports during Modem SIM hot swap enabling: Couldn't get primary port
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] state changed (unknown -> disabled)
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.0590] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/24)
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.0593] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.0596] device (cdc-wdm2): modem state 'enabling'
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.0598] device (cdc-wdm2): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.0601] policy: auto-activating connection 'T-Mobile' (b4835599-4d0d-4ff3-b352-037f415e61ef)
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.0606] device (cdc-wdm2): Activation: starting connection 'T-Mobile' (b4835599-4d0d-4ff3-b352-037f415e61ef)
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.0606] device (cdc-wdm2): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] state changed (disabled -> enabling)
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] simple connect started...
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] simple connect state (4/8): wait to get fully enabled
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] power state updated: on
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] state changed (enabling -> enabled)
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] simple connect state (5/8): register
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] 3GPP registration state changed (unknown -> registering)
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] 3GPP registration state changed (registering -> home)
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] state changed (enabled -> registered)
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] simple connect state (6/8): bearer
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] simple connect state (7/8): connect
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] state changed (registered -> connecting)
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] state changed (connecting -> connected)
Feb 11 14:44:37 xps-9320 ModemManager[1166]: <info> [modem0] simple connect state (8/8): all done
Feb 11 14:44:37 xps-9320 vmnetBridge: RTM_NEWLINK: name:wwan0 index:17 flags:0x000110c3
Feb 11 14:44:37 xps-9320 vmnetBridge: Adding interface wwan0 index:17
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6333] device (cdc-wdm2): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6343] device (cdc-wdm2): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Feb 11 14:44:37 xps-9320 avahi-daemon[1076]: Joining mDNS multicast group on interface wwan0.IPv4 with address 100.66.19.229.
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6345] modem-broadband[cdc-wdm2]: IPv4 static configuration:
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6345] modem-broadband[cdc-wdm2]: address 100.66.19.229/30 brd* 100.66.19.231 lft forever pref forever lifetime 102449-0[0,0] src wwan
Feb 11 14:44:37 xps-9320 avahi-daemon[1076]: New relevant interface wwan0.IPv4 for mDNS.
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6345] modem-broadband[cdc-wdm2]: gateway 100.66.19.230
Feb 11 14:44:37 xps-9320 avahi-daemon[1076]: Registering new address record for 100.66.19.229 on wwan0.IPv4.
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6345] modem-broadband[cdc-wdm2]: DNS 10.177.0.34
Feb 11 14:44:37 xps-9320 vmnetBridge: RTM_NEWROUTE: index:17
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6345] modem-broadband[cdc-wdm2]: DNS 10.177.0.210
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6345] modem-broadband[cdc-wdm2]: MTU 1430
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <warn> [1676155477.6346] device (cdc-wdm2): retrieving IP configuration failed: modem IP method unsupported
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6366] device (cdc-wdm2): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Feb 11 14:44:37 xps-9320 vmnetBridge: Stopped bridge eth0 to virtual network 0.
Feb 11 14:44:37 xps-9320 vmnetBridge: Started bridge wwan0 to virtual network 0.
Feb 11 14:44:37 xps-9320 dbus-daemon[1078]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=1080 comm="/usr/sbin/NetworkManager --no-daemon " label="kernel")
Feb 11 14:44:37 xps-9320 systemd[1]: Starting Network Manager Script Dispatcher Service...
Feb 11 14:44:37 xps-9320 dbus-daemon[1078]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Feb 11 14:44:37 xps-9320 systemd[1]: Started Network Manager Script Dispatcher Service.
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6630] device (cdc-wdm2): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6633] device (cdc-wdm2): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Feb 11 14:44:37 xps-9320 NetworkManager[1080]: <info> [1676155477.6649] device (cdc-wdm2): Activation: successful, device activated.
