I use a Flint 2 replacing the original StarLink router. How do I add a static route to 192.168.100.1 so that the Starlink app will work on iOS WiFi clients?
It shouldn’t be needed. All connected device to a router are - in normal cases - reachable automatically.
Can you please explain a bit more in detail how your network looks like?
It is this scenario: Using a Third Party Router
There is a StarLink app for mobile devices that allows you to see StarLink link information, stats, etc. without the static route the app is not able to connect to the web server supplying the info. All the smarts are in the antenna, the StarLink router I am replacing with the Flint 2 is being bypassed. Hope this is explains the setup, I am currently not on the boat and therefore have no immediate access to the router.
I would say that all traffic will be sent to WAN port anyway when the router does not know any additional routes. Do you use VPN? What is the local network of the router?
Are you getting a public IP via the WAN port from the Starlink “modem”?
Nope, no public IP. It is dynamic.
StarLink says:
“To access the status of the Starlink antenna from within the local network, you must configure a static route to send all traffic for 192.168.100.1 to the WAN port to which the Starlink is connected. Then you can use a web browser to view the Starlink dashboard at http://192.168.100.1”
I can get to the dashboard via WAN but nice and handy to have it via the app. So I guess the issue is that the app is “hardwired”.
If the website works but the app doesn’t, then the app uses something different from just the IP to access. Not an routing issue then.
Thank you, I will give this a shot
I belive that wan is dhcp, should be automatic and gateway is 192.168.100.1
Hmm im going to wild guess.
But i think the app expects the same subnet as the starlink router.
In that case i think the only solution is setting up flint 2 lan as a dhcp client.
Please make a backup before doing anything and then try changing the protocol to dhcp client for lan in luci.
You could also choose to remove one port from br-lan and configure that port as your maintenance port with a different interface and dhcp so you dont have to reset it or have to find back your routers ip ![]()
Basicly for firewall you dont need anything like that you probably want to make some sort of dumbap setup similar as bridge mode.
Hello @Funnyland Is your issue be fixed? Could you please share your firmware version?
Version 4.6.2 and 24 have been tried.
But many more problems have emerged besides Starlink.
Connections are lost for no reason. Worst when a USB HDD is connected.
The whole thing is very strange
Could you show me the system diagram and log? I feel strange too.
I have now repackaged the very defective device and sent it back to Amazon so that I can meet the return deadline.
If you look at the complaints alone on Amazon from users who test the router extensively, you just throw your hands up over your head.
2.4 GHZ problems (connection interruptions) with and without USB.
Device becomes slower especially with VPN.
2.5gb ports slow.
Always only beta software since the start of sales.
From the clock jump firmware back to 21 Snapshot.
The list of defects is simply too long if you want to fully utilize a router.
As you can read in numerous forums, these defects are not just in one device but in many.
A pity
So new round of new happiness.
Amazon sent me a new device. Let's start with how should it be configured with Starlink???
I found this link but I can't enter it like this:
Firmware 24 is installed on it via U-Boot.
It was noticed that Wifi 2.4 crashes with standard settings without the hard drive connected.
What's wrong, no one here anymore????
logread.tar (117.5 KB)
So what is the issue of your side? Cannot find the UI or cannot input values?
