Hello, I was hoping to find some information on setting up the GL1200 w/Starlink. I have read that the Starlink router needs to be in bypass mode, I can’t find any info on how to setup the GL1200. Thx for the help.
Hopefully you don’t want to use incoming VPN/ports since Starlink does not support any kind of port forwarding.
If you just want to use the internet you can simply connect the router with the Starlink dish an everything will work out of the box.
Possibly related:
