I know that we should be patient but when can expect this ?
I recently tried a v3 firmware on the MT300N V2 which was temporarily on the firmware web site and it worked well as a Wireguard server (unfortunately Wifi didn’t work).
I haven’t posted any comments or bug reports (as I subsequently read that until the v3 firmware is formally released it is not suitable for end user testing) but this this firmware looks really exciting !
Just an update trying the V3 firmware on my MT300A.
It is working well as both a Wireguard and Open VPN client via Wifi, USB tethering to a mobile phone and as an AP via Ethernet.
However it is impossible to change the Wireless channel and modes using the GLi interface - however you can change these parameters using the Luci GUI.
Hi alzhao, desperate for v3 for mt300a-v2 firmware as I’m completely lost with trying to get Wireguard running on terminal command lines.
Could you please let me know when you are going to release the update?
Just an update I tried the Shadowsocks Client (using the 750S install instructions) on my MT300A and it works very well with my home Shadowsocks server.
Latency with Shadowsocks is very high 1000mS compared with less than 100ms with Wireguard on the same route. Is this just due to the protocol ?
Hi @kyson-lok I apologise for being stupid to start with.
My setup: 2 x M300N-v2 routers
1 connected to home LAN - router named MiniServer
1 connected by Wi-fi to an android phone with data hotspot - router named Mini Client
Both routers have internet connections.
I set up MiniServer as the server and is attached to lan via cable.
I set up MiniClient as the client that I want to be able to travel with.
I’ve followed the instructions on v3 for the installation of Wireguard and I think I get it however I only get a yellow/orange status button and an Abort button. I don’t seem to be able to make the connection.
Could you please confirm that I’ve got these the right way round - server and home, client to travel? I’ve tried both ways and the same result.
I have not made any other changes,
Interface IP is 10.0.0.2/32
Peer allowed IPs are 0.0.0.0/0
DNS is blank
Could you please tell me what I’m doing wrong? Really frustrating.
Just updated to the latest V3 MT300N-V2 testing firmware.
With the MT300N-V2 as a wireguard server i have dns leaks - whatever setting I select in the MT300N-V2 Custom dns server menus .
I have enabled the following -
DNS Rebinding Attack Protection
Override DNS Settings for All Clients Help
DNS over TLS from Cloudflare
and still my mobile network’s DNSs are shown on http://ipx.ac/ and dnsleak when a wireguard tunnel is operating.
I had the 3.0 beta firmware loaded on MT300N-V2 in order to run VPN. I tried to test WireGuard on this v3.0 too since I failed the DIY process on v2.27 firmware. The 3.0 interface is much better for the CS beginner like me.
I managed to run WireGuard on remote server build on Google Cloud. However, only my PC on LAN connection works but not over WiFi.
Is it supposed to like this, or is it still under development?
So I have port forwarded and put the miniserver into DMZ on main router. Can access internet by connecting via Wi-fi to miniserver. Cannot ping local DHCP IP assigned by main router from outside internet. Don’t k ow if this is an issue with main router or something I’ve not set correctly on miniserver.
Is the IP address in Wireguard supposed to be changed or left at 10.0.0.0?
Do I have to change ANY settings in Wireguard other than leaving as default and making sure confit is copied to miniclient?
Thanks!
M
Just updated gl-mt300a-3.005-1024.bin and a a couple of comments -
1, I’ve configured the switch to toggle Wireguard on and off. Unfortunately it is not very reliable - if I have the switched to ON and I power up the MT300A the Wireguard client fails to start. I have to start the wireguard client from the web interface. Once I’ve have started the client the switch appears to work properly.
2, Very minor but the client/server list ordering in the UI is different for Shadowsocks compared to the other VPNs available.
The Internal SD-card and external USB storage status and file list used to be shown on the Gl-Inet UI but is no longer there. The devices are found via Samba on my connected Linux pc though.
The problem of my mobile network’s DNSs leaking on Wireguard is fixable by defining the desired DNS (1.1.1.1 for me) in the Wireguard configure file for the client on my Android 'phone (see WireGuard on Kali | Kali Linux Blog).
Hope this is of use looking - forward to 3.005 for my companion MT300N V2.
Nevermind, I managed to use the free trial version of mullvad vpn using the build-in feature in firmward 3.0. It seemed working very well; even though I am not going to subscribe the service due to the hight rate.
Now I need to figure out how to build a working visual server on google cloud.
‘Again, the toggle does not work always as pseudonoise said above sometimes we need to login the UI to manually connect the WireGuard server.’
