VLANs not querying Pi-hole correctly
Hello everyone,
My network is separated in three different VLANs:
  1. LAN: PC, smartphones, media devices
  2. Homelab: self-hosted apps like Pi-hole
  3. IoT: smart TV, vacuum robots, cameras
What I want to achieve is to have every device use my Pi-hole as DNS server (192.168.10.20). I can see in Pi-hole that queries are being logged from all devices in the same network as Pi-hole itself (VLAN2).
firefox_b3iQ2U0fog
However, devices on VLAN1 don't seem to be logging queries on Pi-hole which is odd, because I have set custom DNS servers on all three VLAN interfaces.
firefox_GWAzEP8hTQ
Pi-hole does not show any type of query coming from VLAN1 (192.168.8.0/24) even though it has access to Pi-hole.
So to test if the same happens on VLAN3, I connected to the Wi-Fi network associated with VLAN3 and tried to browse the internet which did not work. I then added internet access for VLAN3 and added a traffic rule which allows VLAN3 to access the Pi-hole.
firefox_RDiXzmuqdW
And for some reason, all queries coming from VLAN3 are correctly going to Pi-hole and Pi-hole is logging all the queries from this VLAN, with hostname and all.
My question is: why is VLAN1 not querying Pi-hole even though it can access the entire VLAN that Pi-hole is sitting in? And why can VLAN3 query Pi-hole correctly if it's blocked from accessing the VLAN but has a special rule to allow access to Pi-hole?
I've tried adding the same traffic rule from the other two VLANs but not only did this not change anything, I don't think it should be necessary because both VLAN1 and VLAN3 have zone forwardings to VLAN2.
Any help would be much appreciated. I'm still very new to networking but trying to learn as much as I can.
hmm that sound rather strange.
But i do see something here which might give some further ideas why it fails to work.
I see you forward zone lan to wgclient, however if the vpn is up there is a chance the killswitch blocks it.
Have you enabled this setting aswell?
Allow access to lan? In the vpn options?
If you have vpn policies aswell please let me know this.
In the past ive used the command ip rule to get the mark to use on other networks with the split tunnel for wan to accept packets that worked for me but i dont know it is something like that.
You can try using the dns as gateway ip on each device that should cover the firewalling issue since the router gateway is allowed on 0.0.0.0 and just forwards aslong you remove option 6 and add it inside the dhcp forwardings in luci->network->dhcp options, so for vpn if your virtual ip was 10.0.8.1, you can use 10.0.8.1.
So I disabled the VPN to test if there was any changes, but unfortunately none of the queries (except still VLAN3) are being logged by Pi-hole. The weird thing is, VLAN4 (guest network) and VLAN3 are configured exactly the same but queries from VLAN4 are not going to Pi-hole. I can constantly see queries coming in Pi-hole from my phone when I'm on the Wi-Fi associated with VLAN3, but the moment I switch to VLAN1 or 4, nothing is being sent to Pi-hole anymore.
firefox_Hz83J6PuXa
If I enter Pi-hole's IP address in the DNS settings as shown below, all queries are going to Pi-hole but Pi-hole is reporting all queries as coming from the router. For some reason, the DNS server sent to devices will be the router's IP address instead of the Pi-hole address that I entered.
That is normal because the router will act like a DNS proxy in that case.
Aha, thanks for posting a new screenshot of the firewall zones :+1:
Please ensure the input field for all non wan zones are set to accept.
This is essential to accept vlan frames aswell, in your traffic rules i see you copied the guest rules these are kinda redurant when you use the input field to accept.
Forward should be reject, and output is fine as accept, now incoming connections sent from the router are accepted in homelab and iot, however homelab and iot cannot talk (forwarding) to other zones.
now if you want to make the dns accessible from lan to iot and others you need traffic rules like (you probably have them already):
proto: tcp+udp
src: iot
dest: lan
dest_ip: your dns
dst port: 53
target: accept
Then re-add the dhcp option 6 in your iot and homelab dhcp :+1:
If that doesn't work can you please look into rebind protection?, look in openwrt logs if it shows something or in pi-hole.
Thanks for your reply.
I don't have a physical port for the IoT zone, it's only a Wi-Fi network and a separate interface. I don't want IoT devices to be able to access my router, which is why I have set it up exactly as the guest network.
I think it's easier if I post a screenshot of my entire firewall config:
So in my situation, LAN (VLAN1) and Guest (VLAN4) should already have access to Homelab (VLAN2) where my Pi-hole is hosted. So I don't need a separate traffic rule like I have for IoT and Guest. But Pi-hole is still not receiving queries correctly from LAN or Guest. I even granted Homelab access to LAN because maybe Pi-hole needs to talk back to the devices on LAN that are trying to send queries, but that also doesn't work. Unfortunately I just don't really understand what is happening anymore.
It's beyond me why IoT queries are being sent correctly to Pi-hole and and LAN/Guest queries are not. It's proving to be a lot more difficult than I can handle because I don't have a lot of knowledge or experience in networking stuff.
Could you sent the code of /etc/config/network by chance?
You can use winscp, just type the routers address and password from router, it works very similar as with filezilla/ftp.
And inside the wireless if you edit the AP, have you unchecked the isolation checkbox?
I know with gl firmware on the mtk sdk this often is default active... please restart the router if you needed to change this.
Here's my config! Isolation was not activated on the AP.
config interface 'loopback'
        option device 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fdcd:1692:9811::/48'
config device
        option name 'br-lan'
        option type 'bridge'
        option macaddr '94:83:c4:a4:36:56'
        list ports 'lan1'
        list ports 'lan4'
        list ports 'lan5'
config device
        option name 'lan1'
config device
        option name 'lan2'
config device
        option name 'lan3'
config device
        option name 'lan4'
config device
        option name 'lan5'
config interface 'lan'
        option device 'br-lan'
        option ipaddr '192.168.8.1'
        option ip6assign '60'
        option isolate '0'
config device
        option name 'eth1.6'
        option macaddr '94:83:c4:a4:36:54'
config interface 'wan'
        option device 'eth1.6'
        option proto 'pppoe'
        option force_link '0'
        option ipv6 '0'
        option classlessroute '0'
        option metric '10'
        option username 'internet'
        option password 'internet'
        option vlanid '6'
        option disabled '0'
        option peerdns '1'
config interface 'wan6'
        option proto 'dhcpv6'
        option device '@wan'
        option disabled '1'
config interface 'tethering6'
        option device '@tethering'
        option disabled '1'
config interface 'wwan6'
        option device '@wwan'
        option disabled '1'
config interface 'guest'
        option ipaddr '192.168.9.1'
        option multicast_querier '1'
        option igmp_snooping '0'
        option isolate '0'
        option bridge_empty '1'
config interface 'wwan'
        option proto 'dhcp'
        option metric '20'
config interface 'secondwan'
        option ipv6 '0'
        option proto 'dhcp'
        option metric '15'
config interface 'secondwan6'
        option device '@secondwan'
        option disabled '1'
        option metric '15'
config interface 'modem_1_1_2_6'
        option disabled '1'
        option device '@modem_1_1_2'
config rule 'policy_direct_rt'
        option lookup 'main'
        option suppress_prefixlength '0'
        option priority '1100'
config rule 'policy_default_rt_vpn'
        option mark '0x8000/0xc000'
        option lookup '8000'
        option priority '1101'
        option invert '1'
config rule6 'policy_direct_rt6'
config rule6 'policy_default_rt_vpn6'
        option invert '1'
config rule 'policy_default_rt_vpn_ts'
        option priority '1099'
        option mark '0x80000/0xc0000'
        option invert '0'
config device
        option name 'br-homelab'
        list ports 'lan2'
        list ports 'lan3'
config device
        option name 'br-iot'
config interface 'homelab'
        option device 'br-homelab'
        option ipaddr '192.168.10.1'
config interface 'iot'
        option device 'br-iot'
        option ipaddr '192.168.11.1'
config interface 'wgclient'
        option proto 'wgclient'
        option config 'peer_2001'
        option disabled '0'
So far this looks okay of course there is room for improvement:
for each interface you created, can you edit it in luci and then in advanced uncheck the default gateway checkbox?
^ this however probably won't fix the issue but let me explain why this option could be better be unchecked.
This checkbox is basicly only ment for 'special' interfaces such as lan, or wan like type interfaces, when you have a other interface with this checked then a issue could arise for example: iot goes over the interface gateway of homelab and then to wan instead of iot -> wan which is the default gateway (this is what this checkbox means).
My suspicion though might be that your dns requests are filtered, can you check in luci -> dhcp and check if rebind protection is unchecked, filtering private, can you also check if this is also happening on the pi-hole ?, maybe its blocking it due to different range.
I have unchecked default gateway for the Homelab, IoT and Guest interface, thanks for the tip. Rebind protection is unchecked and filter private is checked, should I uncheck filter private?
I have Pi-hole set to "Permit all origins" so I believe it is configured properly (unless there are more options to change that I am unaware of).
Maybe important to note, I'm on version 4.6.3-op24 instead of the original Flint 2 firmware.
yes you can try this.
however I think I gonna try to check your setup on my own environment to see why its not working :slight_smile:
Please let me know if you've managed to get it to work. I've given up for now and did a complete reset of my router. The VLAN stuff is too complicated for me so all my devices will just be in the same subnet. I had a lot of issues with getting Home Assistant to discover devices on differen subnets as well.
But let me know if you've found the solution because maybe I'll try again in the future. And thanks for all your help.
I got my setup working :wink:
note that when I started configuring the vpn especially with the auto profile then I came into issues.
I was using mullvad for this example, but mullvad has its own configuration hardcoded in /etc/config/wireguard you have to replace the dns entries to the one provided by your own dns.
secondly I also disabled Allow Custom DNS to Override VPN DNS inside the gl ui inside the dns settings, I'm not sure if it does something special but im always afraid of new functions :slight_smile:
^ after some further testing there is still a problem with the vpn, dns route from gateway ip instead of the client.... this is more a issue with the gl firmware i think, maybe just delete the full dns field in /etc/config/wireguard fixes it.
here are my configurations so you can compare those :slight_smile:
the contents of /etc/config/network
        option device 'lo'
        option ula_prefix 'fd41:3898:e437::/48'
config device
        list ports 'lan1'
        list ports 'lan4'
        list ports 'lan5'
# note usually you would take note of the device lan1, lan2 etcetera in normal OpenWrt these must be unconfigured (I don't know why gl-inet specifies those)
        option isolate '0'
        option device 'eth1'
        option proto 'dhcp'
        option ipv6 '0'
        option metric '10'
        option vlanid '0'
        option peerdns '1'
        option disabled '1'
        option disabled '1'
        option disabled '1'
        option force_link '1'
        option isolate '0'
        option disabled '1'
        option proto 'dhcp'
        option metric '20'
        option ipv6 '0'
        option proto 'dhcp'
        option metric '15'
        option device 'lan1'
        option disabled '1'
        option metric '15'
        option disabled '1'
        option invert '1'
        option invert '1'
        option invert '0'
config device
        list ports 'lan2'
        list ports 'lan3'
        option defaultroute '0'
config device
        option config 'peer_2004'
        option disabled '0'
the contents of /etc/config/firewall
config defaults
        option input 'DROP'
        option output 'ACCEPT'
        option forward 'REJECT'
        option flow_offloading '1'
        option flow_offloading_hw '1'
        option synflood_protect '1'
config zone
        option name 'lan'
        list network 'lan'
        option input 'ACCEPT'
        option forward 'ACCEPT'
config zone
        option name 'wan'
        list network 'wan'
        list network 'wan6'
        list network 'wwan'
        list network 'secondwan'
        option input 'DROP'
        option masq '1'
        option mtu_fix '1'
config forwarding
        option src 'lan'
        option dest 'wan'
        option enabled '0'
config rule
        option src 'wan'
        option proto 'udp'
        option dest_port '68'
        option target 'ACCEPT'
        option family 'ipv4'
config rule
        option name 'Allow-IGMP'
        option src 'wan'
        option proto 'igmp'
config rule
        option name 'Allow-DHCPv6'
        option src 'wan'
        option proto 'udp'
        option dest_port '546'
        option family 'ipv6'
config rule
        option name 'Allow-MLD'
        option src 'wan'
        option proto 'icmp'
        option src_ip 'fe80::/10'
        list icmp_type '130/0'
        list icmp_type '131/0'
        list icmp_type '132/0'
        list icmp_type '143/0'
config rule
        option src 'wan'
        option proto 'icmp'
        list icmp_type 'echo-request'
        list icmp_type 'echo-reply'
        list icmp_type 'bad-header'
        option limit '1000/sec'
config rule
        option src 'wan'
        option dest '*'
        option proto 'icmp'
config rule
        option name 'Allow-IPSec-ESP'
        option src 'wan'
        option dest 'lan'
        option proto 'esp'
config rule
        option name 'Allow-ISAKMP'
        option src 'wan'
        option dest 'lan'
        option dest_port '500'
        option proto 'udp'
config include 'nat6'
        option path '/etc/firewall.nat6'
        option reload '1'
config include 'glblock'
        option type 'script'
        option path '/usr/bin/gl_block.sh'
        option reload '1'
config zone
        option name 'guest'
        option network 'guest'
        option input 'REJECT'
config forwarding
        option src 'guest'
        option dest 'wan'
        option enabled '0'
config rule
        option name 'Allow-DHCP'
        option src 'guest'
        option proto 'udp'
        option dest_port '67-68'
config rule
        option name 'Allow-DNS'
        option src 'guest'
        option proto 'tcp udp'
        option dest_port '53'
config include 'vpn_server_policy'
        option path '/etc/firewall.vpn_server_policy.sh'
        option reload '1'
        option enabled '1'
config zone
        option name 'homelab'
        list network 'homelab'
config forwarding
        option src 'homelab'
        option dest 'wan'
config rule
        option name 'allow-dns-lan'
        option src 'lan'
        option dest 'homelab'
        list dest_ip '192.168.10.89'
config rule
        option name 'allow-pihole-web'
        option src 'lan'
        option dest_port '80'
config zone
        option name 'iot'
        list network 'iot'
config forwarding
        option src 'iot'
        option dest 'wan'
config rule
        option name 'allow-dns-iot'
        option src 'iot'
config redirect 'dns_vpn'
        option name 'dns for vpn'
        option src 'lan'
        option src_dport '53'
        option dest 'lan'
        option dest_port '1653'
        option mark '!0x8000/0xc000'
        list proto 'tcp'
        list proto 'udp'
        option enabled '1'
config redirect 'dns_vpn_guest'
        option name 'dns for vpn guest'
        option src 'guest'
        option dest 'guest'
        list proto 'tcp'
        list proto 'udp'
        option enabled '1'
config zone 'wgclient'
        option name 'wgclient'
        option forward 'DROP'
        option mtu_fix '1'
        option network 'wgclient'
        option enabled '1'
        option input 'DROP'
        option masq '1'
        option masq6 '1'
config forwarding 'wgclient2wan'
        option src 'wgclient'
        option dest 'wan'
        option enabled '1'
config forwarding 'lan2wgclient'
        option src 'lan'
        option dest 'wgclient'
        option enabled '1'
config forwarding 'guest2wgclient'
        option src 'guest'
        option enabled '1'
config forwarding 'wgclient2lan'
        option dest 'lan'
        option enabled '0'
config forwarding
        option src 'iot'
config forwarding
the contents of /etc/config/dhcp the only change i made was `Local service only' to be unchecked but i think this might not be needed.
config dnsmasq
        option domainneeded '1'
        option localise_queries '1'
        option rebind_protection '0'
        option local '/lan/'
        option domain 'lan'
        option expandhosts '1'
        option cachesize '1000'
        option authoritative '1'
        option readethers '1'
        option leasefile '/tmp/dhcp.leases'
        option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
        option localservice '0'
        option ednspacket_max '1232'
config dhcp 'lan'
        option interface 'lan'
        option start '100'
        option limit '150'
        option leasetime '12h'
        option dhcpv4 'server'
        option force '1'
        list dhcp_option '6,192.168.10.89'
config dhcp 'wan'
        option interface 'wan'
        option ignore '1'
config odhcpd 'odhcpd'
        option maindhcp '0'
        option leasefile '/tmp/hosts/odhcpd'
        option leasetrigger '/usr/sbin/odhcpd-update'
        option loglevel '4'
config domain
        option name 'console.gl-inet.com'
        option ip '192.168.8.1'
config domain
        option ip '::ffff:192.168.8.1'
config dhcp 'guest'
        option interface 'guest'
        option start '100'
        option limit '150'
        option dhcpv6 'disabled'
        option ra 'disabled'
config dhcp 'secondwan'
        option interface 'secondwan'
        option ignore '1'
config dhcp 'homelab'
        option interface 'homelab'
        option start '2'
        option limit '150'
config host
        option name 'raspberrypi'
        option ip '192.168.10.89'
        option mac '<snip>'
config dhcp 'iot'
        option interface 'iot'
        option start '100'
        option limit '150'
as for wireless I don't think I have to post it but this should work :wink:
you can also forward zone homelab and iot to wan aswell, I forgot it :stuck_out_tongue:
So after a lot of testing it seems that the VPN is indeed the culprit. When I turn the VPN off, all queries are being logged by Pi-hole. However, I still want to be able to use WireGuard client on my router. I removed the DNS line in etc/config/wireguard but that didn't help. Did it work for you? Or did you find a different way to point your DNS server to Pi-hole when using WireGuard on your router?
Update: I readded the DNS line with my Pi-hole IP's address and now all queries from all VLANs are correctly going to Pi-hole with WireGuard client activated on the router. But, this results in every query originating from "GT-M6000.lan". Is there a way Pi-hole can see where the query is coming from instead of the router?
Unfortunately i was unable to, maybe @ywp or @bruce has a idea to accomplish this with this certain setup?
So I found out some more and maybe you can point me in the right direction. When the VPN is active, Pi-hole is receiving queries from both the router and my local device from a different subnet. They're the exact same queries but Pi-hole is only logging the one coming from the router (I changed the IP addresses to name for easier reading):
14:30:09.330297 IP desktoppc.lan.64395 > pi.hole: 27934+ A? b.thumbs.redditmedia.com. (42)
14:30:09.330548 IP router.lan.54563 > pi.hole: 50845+ A? b.thumbs.redditmedia.com. (42)
14:30:09.330611 IP desktoppc.lan.60347 > pi.hole: 16678+ A? styles.redditmedia.com. (40)
14:30:09.330728 IP router.lan.53769 > pi.hole: 44735+ A? styles.redditmedia.com. (40)
14:30:09.331528 IP pi.hole > router.lan.54563: 50845 2/0/0 CNAME dualstack.reddit.map.fastly.net., A 151.101.37.140 (103)
14:30:09.331623 IP pi.hole > desktoppc.lan.64395: 27934 2/0/0 CNAME dualstack.reddit.map.fastly.net., A 151.101.37.140 (103)
14:30:09.331666 IP pi.hole > router.lan.53769: 44735 2/0/0 CNAME dualstack.reddit.map.fastly.net., A 151.101.37.140 (101)
14:30:09.331719 IP pi.hole > desktoppc.lan.60347: 16678 2/0/0 CNAME dualstack.reddit.map.fastly.net., A 151.101.37.140 (101)
So now I know that when the VPN is activated, there's like a "double-query" of some sort going on. I don't have any special rules applied in my WireGuard config other than DNS = pi.hole. Do you know how I can either stop WireGuard from querying as well or make sure that the query from local LAN is received rather than WireGuard?
Unfortunately i cannot, in the previous post i tagged some gl-inet staff/devs in the hope they have a solution :slight_smile:, i guess they are back monday.
What you see here is likely something in their software which they use also as part of the killswitch to avoid dns leaking, however i'd still wish it to be a option because this prevents it for using the dns directly from inside of the vpn tunnel.
May can try to deploy the wireguard and ADG in the pi-hole to solve.
This issue probably related to the DNS traffic of the VPN client in the GL router, here refer to:
It already in the develop plan, will improve this issue.
Hi Porto779,
Try adding a firewall rule as shown in the following figure.
And keep 'Override DNS Settings of All Clients' is disabled.
You must ensure that the DNS of the zone lan can be forwarded to zone homelab.
This may help resolve the issue you are experiencing。
Where and how do I add this rule? Do I just copy & paste those lines in SSH? I can't find an option to add a custom firewall rule in the GUI.
