VPN Cascading on GL.iNet routers
You're right, sorry about that. I’ve actually referenced my device model and firmware version in a more recent thread here:
I recently bought a Slate AX, and the first thing I did was update it to the latest firmware (v4.7).
When both the VPN server and VPN client are running, I’m unable to connect to the server. However, if I disable the VPN client on the router, I can connect to the server without any issues.
I then downgraded to version 4.6.11, and everything works perfectly.
To verify, I tried upgrading to 4.7 again, but the issue reappears, I can’t connect to the VPN server while the client is enabled regardless of whether VPN Cascading is on or off.
I want to know how does the Slate AX connects to the Internet?
Is it connected to the ISP directly or you have another router and set up port forward?
The Slate AX is connected directly to the ISP modem via ethernet cable. Ports are also forwarded.
Currently my router is shared to the GLinet staff via goodcloud for testing this issue
At least this is not necessary because you connected to the ISP directly.
