I set my OpenPVN configuration for CyberGhost as was suggested in the tutorial.
Unfortunately, I get no connection. Appreciate your support, what I am doing wrong.
BR
Rachid
You wrote CyberGhost but the configuration file is called NordVPN?
Talking about NordVPN:
It does not matter Nord or Cyberghost, the problem is that you used the wrong VPN connection username and password.
