The VPN options aren't available in my admin panel.
I am not in China, I am in Thailand.
How do I get the VPN options?
Where did you buy the device?
What label shows as place in the below image in your admin panel?
If it is 'CN', please contact your purchased way to replace to the global version.
I purchased from Lazada Thailand.
And yes, there is a CN on the admin panel. I must have gotten the China version. I'll try to return/exchange it.
So I can't just load a different firmware? Are the devices physically different? I had no idea.
Thank you all!
No, unfortunately it's not a firmware issue - the device type for CN devices is different. Exchanging is the only supported way to get the international version.
-Redacted-
No, this does not work.
-Redacted-
Give it a try, but I highly doubt it - because the "lock" isn't inside the firmware itself.
--EDITED--
In respect with GL's statement about version switching.
I'm sorry for any troubles it might had caused.
A post was split to a new topic: Uboot does not work on Flint2
