VPN policy in GL-AX1800 error
Hi all,
I am trying to connect two GL-AX1800 (link to other post). The net is:
  1. setup AX1800-A as Wireguard server (10.0.0.1)
  2. setup AX1800-B as Wireguard client and connect to AX1800-A through Wireguard
  3. setup “VPN Policy Base on the Client Device” , allow my PC to use VPN
I have fix the configuration but I have a new problem. When the client between routers is connected, if I connect SSH to AX1800-B and I execute “nslookup google.com” I don’t have any reply. This is because it is routing through AX1800 A and not WAN link.
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 38 byte packets
1 10.0.0.1 (10.0.0.1) 21.635 ms 22.244 ms 22.190 ms
Are there any configuration to route the router traffic to my WAN and not through WGclient?
Thanks
I think is the same issue with DNS, Wireguard and AdGuard.
If I stop AdGuard or Wireguard the nslookup in the router works.
I hope an update.
Thanks
Command run by nonevpn usergroup will not go through VPN.
sudo -g nonevpn nslookup google.com
Off-topic: slight criticism: novpn would be a better English translation… unless novpn is already used for a different function, of course.
Appreciated for that advice.
