Wireguard disconnect and down internet
Hi all,
I have a problem with Wireguard client, I have a GL-AX1800 and I connect to other GL-AX1800 throuht Wireguard.
All is working fine, I use “VPN Policy Base on the Client Device” with one LAN device. This device use the VPN and the others use WAN directly.
But if I disconnect the server, all other devices in the client LAN lost internet connection. I think is a DNS problem.
AX-1800 (192.168.0.0) → WireguardClient (10.0.0.4) → Wireguard Server (10.0.0.1) → AX-1800 (192.168.8.0)
The config file of Wireguard is
[Interface]
Address = 10.0.0.4/24
PrivateKey = XXXXXX
DNS = 192.168.0.1
MTU = 1420
[Peer]
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = XXXXXX.glddns.com:51820
PersistentKeepalive = 25
PublicKey = XXXXXX
I have changed DNS by others (8.8.8.8, 64.6.64.6) whithout fix it.
If I shutdown the client the internet connection is working again.
Thanks!!!
hi,
What is the version of your devices? I have tried with version 4.4.6 and version 4.5.0, and didn’t reproduced. These are my steps:
  1. setup AX1800-A as Wireguard server
  2. setup AX1800-B as Wireguard client and connect to AX1800-A through Wireguard
  3. setup “VPN Policy Base on the Client Device” , allow my PC to use VPN
  4. disable Wiregurd server
  5. use my phone behind AX1800-B to access internet, it works.
Did my steps match with yours?
Both AX-1800 are in v4.4.6
The steps are similar, with this configuration file.
  3. setup “VPN Policy Base on the Client Device” , allow my TV to use VPN
  4. disable Wireguard server
  5. use my PC behind AX1800-B to access internet, it doesn’t work.
  6. Stop client
  7. My PC access to internet.
I could try if my TV has internet o not.
And I am using ADguard also.
Thanks!
hi,
It is a known issue of conflict between ADguard and vpn policy. Please using vpn policy without ADguard enabled. My colleague is looking for a way to make both compatible.
Are you sure about that?
I am using AGH + vpn policies without any problem.
yes. It does not appear all the time. It appear when firewall rules of adg and vpn policy are messed up.
Thank you,
we have find a error in our configuration. In the AX-1800-B where is the Wireguard client I had configured a Wireguard server also and the IP os this Lan (10.0.0.1) was the same of the other router server.
I have changed my wireguard server IP to 10.0.1.1 and I don’t have any lost of internet access when the other server down.
We want to continue doing other test, but, apparently, it seems to work.
Thanks!
