I am a customer of GL.inet Flint AX1800 router. I am running firmware 3.213.
There is an issue with the router that during booting before the OS starts, the router switch is working and acting as switch which lead to leakage of DHCP packets from the WAN router side (I have 2 WANs) and confusion in the network until all devices in the network are disconnected/reconnected after boot to get proper DHCP from the Flint.
I saw a commit on GitHub referencing this issue in GL-inet openwrt fork repo, and I wanted to report that this issue is present in Flint as well.
If there’s any workaround I can apply in SSH let me know, for example to keep the switch disabled until OS boot then enable the switch after VLAN/ interface setup. I saw some code in shell scripts with delay_lan_power variable somewhere near /etc/init.d/firewall.
@alzhao perhaps it can be adjusted by modifying bootloader nvram variables ? But you need to be careful to avoid disabling the debrick LAN method (which will need the switch to be reactivated).
Trying to compile the uboot image, following the steps provided on the github, I keep getting this error:
ca@CA-Ubuntu:~/uboot/sdk32$ make package/feeds/base/uboot-qca-ipq6018/compile V=s
awk: include/scan.awk: line 21: function asort never defined
configuration written to .config
make[1]: Entering directory ‘/home/ca/uboot/sdk32’
make[1]: *** No rule to make target ‘package/feeds/base/uboot-qca-ipq6018/compile’. Stop.
make[1]: Leaving directory ‘/home/ca/uboot/sdk32’
make: *** [/home/ca/uboot/sdk32/include/toplevel.mk:181:
package/feeds/base/uboot-qca-ipq6018/compile] Error 2
Can anyone help me out with this, or share the file directly?
