📣 We’re exploring the next generation of our Spitz and Puli series
We’re currently evaluating the next versions of Spitz and Puli, and we’d love to hear from you.
As user needs continue to evolve, we’re gathering feedback from our community to help shape what comes next. What features, improvements, or upgrades would you like to see in the next generation?
:backhand_index_pointing_down: Share your thoughts here:
We’ll carefully review all of your valuable feedback. While we can’t promise every idea will make it into the final product, your input will help guide what we build next.
Better VPN performance. One or two more gigabit ports would be great if they can be squeezed in somewhere.
I have a Spitz AX right now, its amazing for road trips.
Some suggestions:
  • Incorporate the touch screen like new Slate and Mudi for quick access to toggle things on/off like VPN, trigger firmware updates, etc
  • Smaller footprint (for me I travel with it in the back of my SUV)
  • USB-C powered native, today I use a barrel→USB-C adapter. I power the Spitz AX via DC power bank in the car or as needed onsite
  • Bonus: POE powered to use as 5G fail-over. Yes, this is picky, but 1 ethernet providing network + power is great. I have a UniFi stack and it appears POE is picking up alot of adoption in other network brands.
I currently have the Spitz Plus GL-X2000 and I live in the forrest where there's only weak 4G LTE signal.
Some features I miss;
Bridge mode
WiFi Mesh
V-LAN support
USB 3.x
More storage space to be able to upgrade apps
Better support of newer versions of OpenWRT
USB C power
512mb-1024mb ram
1gb rom
Quad core
Smaller spitz
SDX75 or even SDX85 (if avail) Quictel Modem
PoE powered and/or USBC powered
Bridge Mode
Good OpenWRT support
It means a bigger device. Can't have it all. The people who are complaining about the size are effectively saying cut the number of ports.
The Puli needs to have a user-replaceable battery. A more current modem is definitely preferred.
I also want to use it in the car, so maybe better mounting options?
There should be a minimum of 2 GB of RAM. No more proprietary barrel charging port. At a minimum, it should use USB-C for charging. PoE is a great idea, as suggested by someone else.
Do you even own 1? The Spitz only has 2 RJ45 ports, If you look at the physical structure most of the external area is taken up by the external antenna connectors, 6 in total. Id be personally fine with internal wi-fi antennas and internal 5G antennas (like a EERO AP size) with optional external antenna for 5G like the Mudi 7 but I don’t move that far away from the unit when I travel so wi-fi is not an issue in my use case and may not fit everyone else.
I use a barrel→usb-c adapter so you can use a standard DC power bank, but again it’s just one more complexity of stuff to have just for the 5g router. Native USB-C is the way to go
If I needed a smaller portable unit I would buy the Mudi 7. More ports would be more important to me than a smaller size honestly.
Thank you for your feedback!
Our team is still working on the product definition and no final specs have been decided yet.
We will definitely take community feedback into full consideration.
USB -C for sure, maybe some kind of foldable antenna or something similar, built in esim, the rest exaclty as spitzAX
GPS/Traccar Support
Zigbee hub Support
More USB Ports
More LAN ports
4 Detachable antenna sma for wifi 4x4 2,4 5 6 Ghz
8 Detachable antenna for 5G mobil 4x4 mimo for region with poor signal
Esim
Openwrt
Touch like Mudi7
Important to have:
5G global
Based on OpenWRT
Pretty good VPN speeds
At least an option with battery (better if removable and replaceable)
Minimum 2 ethernet ports, maybe even 3.
Removable antennas.
Not too big. I think Spitz Plus is a good middle size. Maybe with a battery and upgrades it can be a new Puli Plus.
Let’s have a quick poll:
How essential is IP Passthrough for your daily usage?
Do you need this feature to use the device as a 5G modem paired with your own home router?
For me IP Passthrough is not important. I do not use it or need it to connect to the home router and home network.
IP passthrough is Not important for me.
