WiFi Works Ethernet cable does not work
Hi, I've just bought an opal router and I tried to connect to it with my laptop through ethernet cable and there is no internet and I can't acces the admin page for the router.
But If I connect on the router and I reload the same pages I tried to access via ethernet cable the load fine through wifi.
Do I need to return the router or is it something I can fix?Any steps I could try?
Do you use the LAN port, not the WAN port?
That's correct, I'm using the LAN Port, NOT WAN(tried the 2 LAN ports I have available but it'sthe same )
Also that's my verison the ui if that helps: Admin Panel v4.3.19
Does the LAN port of your device itself work, so your laptop?
I tried connecting the Ethernet cable to my home router and disable the wifi and seems internet works fine, I tried to run a youtube video and works without problem. One thing I noted is that some websites return unreachable.
Also noticed when I connect with the Eth cable to opal router and disable the wifi I get ERR_ADDRESS_UNREACHABLE as well when I try to visit http://192.168.8.1
Did you change the IP address of your Opal? So what IP do your PC get while connected via Wi-Fi?
Did you run the VPN software in the laptop?
Or does the router run the VPN client with the proxy rule 'based on device MAC' ?
