I’m trying to run wireguard server and client on the same router(GL-AXT1800) but when taking the peer configuration and setting on client there is no internet anymore.
May I ask whether your vpn client uses the global proxy mode? Could you please tell me your firmware version? I will test it with the version you use.thanks
Just tested it, no problem, you can try to change the network segment of the wireguard server, if it still doesn’t solve the problem, can you provide the client configuration generated by the wireguard server of the gl interface
Yes. Im looking a way with glinet ui to forwarding all my lan internal traffic to wireguard server. That why ive done the connections with own client configuration.
