Hey guys,
I’m trying to setup WireGuard VPN between Slate AX (GL-AXT1800) as client to my Asus RT-AX86U as server.
There isn’t much to configure to be honest - I setup new account on Asus router with private/public keys and pre-shared key, exported everything to a .conf file, imported the file to the Slate router but I wouldn’t connect for some reason - log file below.
OpenVPN works perfectly but would like to test WireGuard too.
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Zone ‘wan’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Zone ‘guest’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Zone ‘wgclient’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Set tcp_ecn to off
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Set tcp_syncookies to on
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Set tcp_window_scaling to on
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Running script ‘/etc/firewall.nat6’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Running script ‘/etc/firewall.vpn_server_policy.sh’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Running script ‘/var/etc/gls2s.include’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): ! Skipping due to path error: No such file or directory
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): * Running script ‘/usr/bin/gl_block.sh’
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): Failed to parse json data: unexpected character
Fri Apr 19 13:52:25 2024 daemon.notice netifd: wgclient (27428): cat: can’t open ‘/tmp/run/wg_resolved_ip’: No such file or directory
Fri Apr 19 13:52:26 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Fri Apr 19 13:52:26 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
Fri Apr 19 13:52:26 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Apr 19 13:53:01 2024 daemon.notice netifd: Interface ‘wgclient’ is now down
Fri Apr 19 13:53:01 2024 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Fri Apr 19 13:53:43 2024 daemon.notice netifd: Interface ‘wgclient’ is setting up now
