I have AR750S with latest firmware.
I enabled WireGuard Server.
I made WireGuard User Account.
I imported WireGuard User settings into Windows WireGuard app.
I created other user and imported settings into Android Phone App using QR code.
When I am on the GliNet router’s local wireless network the connection completes and works.
When I connect from the outside to the static IP of my router it starts but handshake does not complete as seen in the logfile of the client.
I tried standard port as well as 81. I dont know if I need to open the ports manually but it does not make a difference whether ports are opened or not.
What other options on the Router do I need to enable?
Yes I have an IP starting with 150.x.x.x.
Besides starting the wireguard server and making user accounts, did you have to set anything else? Open ports, setting firewall or setting interface?
I have Wireguard server running on a B1300 (direct to internet, dynamic IP) with DDNS . Never had to open any ports or anything (besides change client file to point to DDNS name) to get the client running on Windows/Android/GL.Inet devices, so assume that happens automatically.
