I've been looking at this issue for a while but I've not been confident of the source for the information I was finding.
On looking through the information at https://www.wireguard.com/ I could not find configuration file information with respect to DNS settings.
However the man files for wg and wg-quick are authored by the creator, Jason A. Donenfeld, so I'm confident of quoting from them.
So from the man files the DNS statements can be:
- a comma-separated list of IP (v4 or v6) addresses to be set as the interface's DNS servers,
- or non-IP hostnames to be set as the interface's DNS search domains.
- May be specified multiple times.
So this DNS configuration statement:
DNS = 192.168.1.254, fe80::a4cb:8cff:fe83:70ce, example.com
Is functionally the same as the following statements:
DNS = 192.168.1.1
DNS = fe80::a4cb:8cff:fe83:70ce
DNS = example.com
And would be expected to appear as the following in the corresponding /tmp/resolv.conf.d/resolv.conf.wgclientx config file.
nameserver 192.168.1.1
nameserver fe80::a4cb:8cff:fe83:70ce
search example.com
Testing a couple of configurations on my Beryl AX:
VPN Config 1
[Interface]
Address = 192.168.1.55/32
DNS = 192.168.1.1, fe80::a4cb:8cff:fe83:70ce, example.com
PrivateKey = 0A87PHsfU+Wvt8c49xjqFR6rdn2xGpTFTB8M3qK+2EQ=[Peer]
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = wgx.example.com:51820
PreSharedKey = ebwdIcJnaAPqqU4u2tBamP/drw7HEqmAyvnnMAcErfw=
PublicKey = FnRpQdkELqDKhFBITJ2KRWZOlhWrV5fER7leh9FzYjw=
PersistentKeepalive = 25
Beryl AX active config:
root@GL-MT3000:/tmp/resolv.conf.d# cat resolv.conf.wgclient1
# Interface wgclient1
nameserver example.com
VPN Config 2
[Interface]
DNS = 192.168.1.1
DNS = example.com
Interface wgclient1
While the nameserver {IP address} entries are fine.
The nameserver example.com is not as it is not an IP address [and would need to be a FQDN should it have been valid].
While the search domain is never configured.
