Hi all, I am a newbie to glinet routers, and not that tech savvy either (in fact, not at all). Believe me, I tried to look for and read most of the posts first, tried many times with both routers then rebooted and tried again, but still cannot figure it out so I am posting this question. Please help if you can.
I wanted to set up WireGuard server on a router that stays home and WireGuard client on a travel router to have home IP address to work while using the travel router.
My current equipment:
Home in the US: Comcast router -------- Google nest wifi (WAN) -------- (WAN) Beryl AX
Remote location will be similar: ISP router ------ TP Link Mesh (WAN) ------ (WAN) Slate AX (LAN) ------- (LAN) laptop
Here is what I have done so far:
Beryl AX.
Enabled DDNS, ran DDNS test and saw this message ( “the IP address from DDNS domain resolution is not the same as the WAN IP of the device. You need an Internet Public IP address to use Dynamic DNS”) but I proceeded anyway.
Set up Wireguard server
Set up port forwarding on Google nest to BerylAX through Google Home app
Slate AX
Set up Wireguard client
Enabled Wireguard client
but the message “The client is starting, please wait …” stays like that forever. I tested it on my 5g through my phone but no traffic at all.
What did I do wrong?
I tried connect the BerylAX to Comcast router through LAN but there is no internet, the WAN port is taken by the Google Nest.
I tried Port Forwarding from Comcast router to Google Nest but it didn’t work either.
That is almost what happens here. Since the router cannot see the WAN IP, it can't register this IP against the DDNS service. Use https://dnschecker.org/ against your DDNS address to see if it resolves to the right IP.
It works after I did 2 times of port forwarding, from Comcast to Google Nest and then Nest to Beryl AX and tested on a different network than my local network.
