I wonder if there is way to change the Wireguard server address to DDNS instead of current wan ip when it generate the client configuration file.
Also, if there’s way select different domain name instead of hard-coded one in the device?
Thanks
Thanks
Please refer to this instruction. [GL.iNet] Upgrading DDNS Service
You can enable glddns in the router, but it needs a public address to work. If you router is behind firewall, it won’t work.
