WireGuard wont work
I know you are already investing, had the same issue myself as of yesterday after Beryl AX got itself in a tiz and I had to hard reset. I manually configured config files for Nord wireguard and they worked, just server retrieval list on router. Just assumed Nord have changed something. Their API is working for some of the 3rd party scripts that help generate configs so it's not that the whole Nord API is down.
I just use the conf file generated by my VPN service (Surfshark) and it works without an issue
I got the same issue. It looks like you guys already are working on a solution with nord, nothing populates after selecting the servers.
For users encountering this issue, please temporarily refer to the following workaround:
Our R&D team is working hard to communicate with NordVPN to restore API availability as soon as possible.
We confirm that NordVPN has resolved their upstream API availability issue.
All users should now be able to log in directly through the GL.iNet Admin Panel interface using their Access Tokens to fetch and configure WireGuard connections normally.
