Wiregurad VPN won't connect on AX1800
Hello, I have Surfshark VPN and AX1800 travel router, I was able to connect the openVPN to my router as client, but when I try wireguard it won’t connect, anyone had that issue before?
Did you enable the VPN Cascading? I had that same issue before when the router is running VPN client and server at the same time, this trick solved it. (See this post for details: VPN Cascading on GL.iNet routers)
Also, you might want to test if port 51820 is accessible from WAN, some ISPs might block the access of certain ports.
I’ll give it a try, I may end up having my own VPN in the could.
Thnaks
I think that port 51820 is blocked, is their a way around it? or can we use a different port?
