X3000 Critical Uboot Update
Is this the github bin file (627kb) that I should use for the update?
uboot-x3000-20250225-md5-c9d7b2fd2451adbc0bb126e2d9729e87
Have other X3000 users used this file with success or have you had issues?
Does matter which port I use on the router?
Appreciate your time in responding.
GL-iNet - Can you answer this please ^^^^
Thank you.
Both GL-iNet and users are covering the topics here you should look or ask this questions.
I did the update yesterday with that same bin file and it went smoothly. I used the LAN port. It was quick and drama-free.
Waffle,
Thank you, that's just what I needed.
