I have the following problem, I am standing here on a campsite and use the repeater function with Wireguard VPN.
The connection then no longer works sporadically. I can see that my device (cell phone, tablet, etc.) is no longer connected to the Internet and if I want to look at the surface of the Spitz, is that no longer possible? The LEDs on the Spitz flash, the WLAN is also displayed again and again, but I have no connection, neither to the Spitz not to the Internet.
It only helps to pull the plug and restart the router, then everything works again?
Does anyone here have any ideas?
what do you mean with EAP? This is a WIFI from the Campsite and the WIFI is free, but there is a Captive Portal, but this is not a Problem that works…
if i have this Problem, the Interface from the “Spitz” is not available, the only way what is work is to disconnect the electricity from the “Spitz”!!
