but wanted to be able to get to all of the client devices on the subnet as well so found this link very helpful in setting it up how I wanted it. https://kysonlok.gitbook.io/blog/vpn/zeretier
What speeds are you seeing on ZeroTier, if you don’t mind my asking? You can do something similar with Tailscale which is running at probably 80% of OpenVPN speed on the routers I’ve tried.
It would be better if mwan3 played nice with the various setups (Tailscale has been reworked to fix the issue, but I think something about gl-inet’s implementation in 4.X is non-standard, which makes it not work again). It’s really a shame it isn’t supported natively, given that the CLI syntax is simple and the functionality is great.
I haven’t done any benchmarks yet as my intent was to use it to configure settings on a few devices remotely and I don’t have a file server on the remote side. I forgot Tailscale was an option for this as well, thanks.
Sure… I’m considering writing a basic Tailscale guide up, if I get the chance. I’d like to get it working without nuking all of the GLI firmware, but… that takes time.
Upgrading the firmware to 4.2.1 broke the ZeroTier integration I had and the built in integration they added with 4.2 doesn’t work on that router either probably because of some of the changes I had to make to get it working originally. I’ll probably have to restore factory settings to get the new ZeroTier integration to work.
