Hi all,
I’m using version 4.0 on my brand new GL-AXT1800 but I’m having a big issue with VPN policies.
I configured a Wireguard VPN client that is working ok. The client set also the DNS server that is on the other side of the VPN.
Everything is ok until I enable VPN policies.
I set tu allow the use of the VPN only by ad one specific clients setting their MAC addresses. When enabled the DNS resolution isn’t working anymore.
I suppose because the DNS server on the GL-AXT1800 is not allowed to pass trough the VPN and so the DNS server in unreachable.
The option “Services from GL.iNet doesn’t Use VPN” is correctly set to OFF.
I use vpn policies ip/domain and no dns resolution if dns servers are on vpn network, all is ok if I set an e ternai dns server.
On Slate ax and Slate plus, old or new kernel…
Another issue on slate ax is that on router restart no dns resolution if vpn policies are active. I have to stop and start vpn policies to solve issue. Issue is present on old and new kernel. Slate plus is not affected.
My domain/ip list is very long…
