Hi everyone,
I’m seeking advice regarding my current network setup. Previously, I shared my network configuration in this thread: Static Route on Marble GL-B3000 Beta Tester.
Although I had configured both routers successfully at that time, I’m now encountering issues. Devices connected to Router 1 (GL-B3000) are having trouble communicating with devices on Router 2 (GL-AX1800), including difficulties with printing and accessing the network storage on the flash drive connected to Router 2. This is despite the fact that I have set up static routes.
The goal:
- 192.168.8.120 - Device that needs to print
- 192.168.8.130 - Device that needs to access USB flash drive on GL-AX1800
The Target:
- 192.168.10.001 - USB Flash Drive Network Storage
- 192.168.10.121 - HP Printer
I suspect there may be a misconfiguration in my current network topology, but I’m not entirely sure. Any insights or suggestions would be greatly appreciated.
[1] FiberModem <-> [2] Marble (GL-B3000) <-> [3] Flint (GL-AX1800)
IP: 192.168.1.1/24 | 192.168.8.1/24 | 192.168.10.1/24
Mode: Modem | Router | Router
Service: Passthrough | DHCP | DHCP
WAN (Internet) | PPPoE with VLAN ID 500 | Repeater (STA) 5GHz
LAN (Clients) | Smartphone, Computers | IoT Devices
| WiFi 5GHz | WiFi 2.4GHz
SSID | 5GHz160MHz | 2GHz
Security | WPA2-PSK | WPA2-PSK
WiFi Mode | Generic 802.11acan | Generic 802.11nacax
Bandwidth | 160MHz | 20 MHz
Channel | 40 | 11
Frequency | 5.640 GHz | 2.462GHz
[INTERNET]
|-wan
[FIBER MODEM]
192.168.1.1/24
|-lan
|-wan->(PPPoE with VLAN ID: 500)
[GL-B3000]<--------------->[WLAN Devices]
192.168.8.1/24 2.4GHz: IoT ---------------->[Xiaomi Poco X3]
192.168.8.100-249 5Hz: Smartphones, Laptop 192.168.8.120 - Device want to print
|-lan |
| [Xiaomi Poco X5]
| 192.168.8.130 – Device want to access USB Flash Drive at GL-AX1800
|-wan
+------(Multi WAN Load Balance)-----+
|-wlan |-lan (Using powerline but slow only 50-60Mbps)
Load Ratio: 0 Load Ratio: 2
5GHz Repeater (STA) |
192.168.8.2/24 192.168.8.210/24
+------------[GL-AX1800]------------+
192.168.10.1/24 - USB Flash Drive Network Storage
192.168.10.100-249
+-lan
[WLAN Devices] [LAN Devices]
2.4GHz: (Disabled) |
5Hz: IPCam, Smartphone, [Mini-PC 2.5Gbps]
Samsung Tablet, Laptop 192.168.10.121 – HP Printer
Static routes:
Static routes > General Settings:
Static routes > Advanced Settings:
Static routes > IPv6
AX-1800 Static routes > IPv4 rules
AX-1800 Static routes > IPv6 rules
Firewall > Zone Settings
