I have contacted them, and I will update the firmware next week to solve this problem.
Works well on AR300m. Any MT300N version?
Can we get a version of this for the X750 please?
Thanks!
X750 is not powerful enough to run adguard.
It seems with this solution, we cannot create per-client behavior, which is a must for me. e.g. client 192.168.8.20 uses adguard DNS filters, but 192.168.8.21 skips adguard DNS filters, and uses upstream DNS. Is this something that can be fixed in the future?
I am thinking about to “upgrade” from GL-B1300 to GL-S1300 because of larger memory.
Can anybody recommend this step ? Will newer AdGuardHome work on S1300 in the future ?
GL-B2200 isn’t an option, because of only one LAN Ethernet port…
Hello!
Tested AGH on my AR750S but went back to firmware 3.104. Big issues with DNS leaking, even with OpenVPN or Wireguard running, I saw my ISP was always at https://ipleak.net/ in DNS results. I was unable to login to ZeroTier due to my country’s IP being blocked by the US restriction. Even using Cloudflare unable to log into US restricted web pages.
And I have made no changes at all.
Thx
It doesn’t work on 300n-v2, 300n-v2 doesn’t have enough flash.
Where did you download the firmware?
openwrt-mt300n-v2-VPN-Bridge.bin 12289KLast modified: Thu Sep 24 2020 10:00:57 GMT+0700 (Western Indonesia Time)
https://dl.gl-inet.com/firmware/mt300n-v2/testing/
@robotluo Where you able to update the firmware to fix the Adguard version and upgrade issue from before? Could you push a S1300 update if so? Thanks ![]()
Is the final release for the AR750S nearly finished?
Thank you.
pls add adguard to an offical firmware of ar-750s <3 thank you very much
With AR750S I can see there’s dual flash but on Creta (AR750) it says DDR2 128MB / FLASH 16MB is this different?
Wondering with the 128mb DDR2 it has enough space also?
128MB RAM is difficult for adguard to run.
Anyone have a copy of the Convexa-S build? They removed all builds from their servers and I don’t have a local copy. I would really appreciate if someone can share a link.
hi guys, i have the brume mv-1000, and when go into the adguard home settings, i have an update v0.104.1 available. if i click on update now, i got an error, auto update failed.
someone can help me please ?
@robotluo this is the same issue as on S1300, and update on what Adguard said about the fix?
brume mv-1000
firmware: 3.104
AdGuardHome: 0.104.1
AdGuard Home is working; however, if I define a Client, it does not seem to work. For example, I have “Use AdGuard Parental Control Web Service” enabled in the General Settings. I have a Client defined for my device using IPv4 address (also tried IPv6) with “Use Global Settings” disabled and “Use AdGuard Parental Control Web Service” disabled. From this device, I am still blocked to all web sites categorized as “adult”. Is there something I’m missing?
(edit) Some additional info: I am using a Linksys1900AC (access points) in bridge mode forwarding to my MV-1000. The MV-1000 is my DHCP server, gateway, and connected to my cable modem. All requests through AdGuardHome show as localhost (127.0.0.1) instead of each individual client.
- SSH into your mv-1000 → ssh root@ipadressofyourMV1000 → Password is the same as you use to login through your browser
- download the latest version (Linux ARM, 64 bit) → wget https://static.adguard.com/adguardhome/release/AdGuardHome_linux_arm64.tar.gz
- unpack → tar x -zf AdGuardHome_linux_arm64.tar.gz
- stop the AdGuardHome service → AdGuardHome -s stop
- backup the existing app (optional, you can overwrite or delete) → mv /usr/bin/AdGuardHome /usr/bin/AdGuardHome.old
- copy the latest version → cp AdGuardHome /usr/bin
- just in case → cd /usr/bin
- start the AdGuardHome service → AdGuardHome -s start
- You can ensure the service is running by typing → AdGuardHome -s status
Hope this works out for you!
