MV1000 and S1300 updated the 3.105 beta firmware and fixed the AdGuardHome upgrade issue.
The AR750S will not integrate AdGuardHome into the firmware, but I’m updating the snapshots firmware here
Will the snapshot version get updated regularly or the 3.105-1126 will likely to be the last?
Thank you.
In general, the snapshot is updated in sync with our standard version.
I’m unable to download any of the tar files for the AR750S. Have they been removed?
cant download AR750S files either…
any help??
To developer.
The Snapshot version with AGH doesn’t work reliably. A few days ago I could toggle the AGH on with internet connection but today if turned the AGH on the internet connection would drop.
…I’ve realized the AR750s may not be powerful enough to run AGH with large filter lists, but with a default filter list can it be run reasonably well? And If so, by any chance you could improve / modify the AGH Snapshot firmware to be at least as close as the Release firmware version.
I’ve already considered your GL-MV1000W, but it’s missing the 5Ghz signal and that is no deal for me.
I’ll be gladly to wait.
Thank you.
I’ve tired the firmware. It didn’t work reliably for me, the firmware must have been removed for a reason.
@Sam79 @BigHusky Snapshots are often updated. You can find the latest firmware here.
Call the AR750S -agh folder and download the firmware that has the tar suffix.
I can’t find AdguardHome on the latest E750 snapshot build… is there another link I should be using?
Thanks @robotluo. Will you be adding a modified AGH firmware for the recently released 3.105 final build? The only firmware available now is for the beta builds.
Been using the AGH on 3.105 beta 2 for few days. So far so good. except:
Trying to enable encryption under encryption setting will result in below error.
Error: control/tls/validate | port 443 is not available, cannot enable HTTPS on it | 400
Any thoughts?
Can you clarify which is this settings?
Should we expect an AGH version of the final release?
Any update? Can anyone at GL.inet comment on this?
I tried looking myself at the public repos here: gl-inet · GitHub
and couldn’t really find any indication of the v3.105 release nor betas at all nor sources for including AGH.
Unless I’m looking at the wrong repo… :-/
This should be helpful.
From luochongjun’s post
“The AR750S will not integrate AdGuardHome into the firmware”
Something new…
How is your comment helpful at all?? Totally useless!
It’s already integrated into beta versions of the firmware, in case you haven’t already noticed from the 100+ replies to this thread.
Betas with AGH are here buddy: AGH
