bobd
February 27, 2022, 7:57am
At my school , I have problems getting wifi connection via Beryl.
This is what I repeatedly get after pasting in the wifi password.
Beryl router
— > No Internet Connection! Find new networks to reconnect.
— > “Wrong key” message.
…Things I have done:
I have disabled “DNS Rebinding Attack Protection” feature in Beryl router , according to
Tried using MAC Clone.
No captive portal.
All without success.
Any other workaround?
Please advise.
Thank you very much.
wcs2228
February 27, 2022, 3:07pm
2
It may be the same problem reported in this thread:
My beryl was disconnected from hotel wifi this night. I tried to reconnect but was not successful.
I tried rebooting, change WAN mac, delete wifi config and reconnect again, but no success.
When trying to connect, I get a message “wrong key” when trying to connect after searching.
This hotel wifi has no encryption, the password is entered afterwards in a captive portal.
Why cannot I connect anymore, I did the same about 2 days ago and it worked fine
“In WiFi settings, change bandwidth to fixed e.g. HT20. Do not use HT20/HT40.
Do this for both 2.4G and 5G wifi.”
bobd
February 28, 2022, 1:09am
3
Thanks a million.
I shall give it a shot and let you know the results.
alzhao
February 28, 2022, 9:54am
4
Unfortunately, 3.212b1 has introduced the “wrong key” problem on my Mango. I can’t connect to my local networks in repeater mode. Rolling back to 3.211 fixed the problem for me.
alzhao
March 9, 2022, 4:35am
6
Is there anything special with your wifi or key? e.g. length and special characters?
I test again and I can connect Mango to wifi as repeater without problems. I tested several wifi and iphone hotspot as well.
It only displays “wrong key” when I put a wrong key.
Your help to replicate this problem is highly appreciated.
bobd
April 21, 2022, 1:03pm
7
Here is the solution I found to my problem,
Here is my report.
I downgraded to version 3.203.
Does not work.
Got the same message that says.
So I upgraded back to version 3.211
This time , I chose 5 GHz wifi
And , bingo , it seems to work.
I have not done anything different this time.
Except , this time , I chose 5 GHz instead of 2.4GHz.
So , it looks like 2.4 GHz wifi will fail to work with Beryl at my school.
I wonder why I did not choose 5 GHz before and tried.
I guess…
max1
May 24, 2023, 6:19pm
9
Hi! I have similar wrong key issue in my college with mt-300n v2, fw 3.216.
College wifi network with login and password.
Laptop connects without any issue.
alzhao
May 24, 2023, 11:53pm
10
MT300N-V2 does not support EAP. The UI must be buggy. It should not display connecting to the EAP UI.
Pls check the supported models here.
