AT&T network fix
I have received feedback from users that ATT cannot be used. You can try the following steps.
Step 1:
Enter the AT instruction page and execute the command AT+QPRTPARA=3
1 ROXZU%DNUW(9{MDS_9%EMY0
Step 2:
Confirm the modem version and execute the corresponding instruction
For version R05, execute at+qfopen="../../usr/fota_ip_a/update_report.ur",1
For version R07, execute at+qfopen="../../data/fota_ip_a/update_report.ur",1
For EP06, execute at+qfopen="../../data/fota_ip_a/update_report.ur",1
Step 3:
Execute AT command AT+CGDCONT=1,"IP","broadband"
Then, In modem manual Settings, modify your apn configuration to use broadband and click Apply
}98R}0EB({SGWXO(KV{4D4M
Step 4:
Restart your router
