Pressing Continue breaks something as the LANs do not work any longer.
When using the modem Quectel EM06-E with a USB interface, it cannot connect at all with any of the offered protocols although the operator is recognized as well as the signal quality report and AT commands work fine. The same works fine with the older model Beryl (MT1300) using 3g/LTE with gl inet firmware 3.215 and with ModemManager using vanilla openwrt 22.
A1 Do you have hardware acceleration enabled?
There was a issue with it breaking stuff.
A2. You could try a different firmware like the latest snapeshot. I would not keep settings and instead load a config file in LuCI.
Quectel EM06-E is it a M.2 in a USB enclosure. It might not be getting enough power. Could also be a driver issue.
I am using the latest snapshot for the Beryl AX
You may take a look at my experience using eg25-g with mt3000
I THINK they cater the mt3000 to newer 5g modems than legacy LTE modems, but driver update and some configuration file editing should work, that requires developers assistance
It makes no difference whether it is enabled or not in 4.1.3 nor 4.2.0. At least for the LuCI interfaces issue.
I tried the beta and snapshot too. Ofc I did skip keeping settings for all these tests as I’m still testing the device.
But also with 4.2.0 beta, I had further issues as the modem settings were not applied/saved correctly. At least the device path was being truncated to /dev/ instead of keeping /dev/ttyUSBX or /dev/cdc-wdm)
That’s right. I learnt that already with Beryl MT1300 as the included power brick wasn’t giving enough power, so I’ve been using a more powerful one that meets the required Watts for this Quectel and Beryl AX. Like I said, same setup works fine in Beryl MT1300 that has the same power input as the Beryl AX MT3000. But my Beryl MT1300 does have vanilla openwrt 22.
It could be although I believe it is more a software issue (ModemManager and related) since the driver for EP06 (what GL inet use themselves) is the same for the EM06. I really hope they start using openwrt 22 instead 21 for the snapshot/betas soon…
So currently your modem stays alive for just 2 hours? Have you tried with a more powerful power brick? With the one they provided mine was dying eveytime I made a speedtest (intensive usage)
Probably, but they use very similar LTE modems in at least the routers Spitz and Cirrus, EC25 and EP06, so to get them working shouldn’t be a big challenge. Or do these modem have other modules/software packages not included with non-LTE routers? Hopefully someone from GL-inet can shed some light on this.
Ah, almost forgot about the third issue with at least firmware 4.1.3 latest stable release:
3. When using WiFi Scheduled Tasks to turn on and off the WiFis, it would not use the custom settings but would create open WiFis (no Security at all, i.e. WPA, etc) and they would be called MTK_CHEETAH_AP_2.4G and MTK_CHEETAH_AP_5G for the respective frecuencies.
WiFi Scheduled Tasks issue is now resolved in 4.2.0 but 1. and 2. are still the same. Probably 2. EM06-E support won’t work properly until openwrt 22 instead of 21 is used in the gl inet firmware… pity we can’t try latest openwrt vanilla in this router just yet.
WTH. I just bought this on Amazon yesterday as a travel router. The instructions were useless, but luckily I found a decent video.
I set up one 2.4G Wifi Repeater connection. After the long delay and two resets, it was finally working
Next it asks to do a Firmware DL, which I thought would IMPROVE its functionality, and the FW took forever to load on a fast connection, said it was 100% complete. But, it seemed frozen again, so I hard restarted it for the 4th time.
Now, I get this damned MTK_CHEETAH_AP_2.4G mirrored open Wifi connection. A damn wide open front door. WTH is wrong with these developers?
Or, is this some form of insidious malware hiding as a travel router? I dont trust crap from China. I bought this POS for travel security, not insecurity.
WHY is this open connection happening, as others have reported for 9 months?
HOW do I get rid of it without running some rando's script (also a huge security risk)?
nope - never seen that... i've updated mine a number of times from beta and snapshot firmware - but not from firmware that far back (4.1.x days).. mine came with 4.4.6 installed.. (from amazon US) - currently on 4.6.0-op24
I sent the first one back (a mistake it now seems, as at least it auto-updated itself). The 2nd unit, also from current Amazon stock had the same version number as yours, but didnt work, wouldnt connect, did not offer up a firmware update, wouldnt respond after resets, so I've now sent back two of these.
I give up.
But, as far as the bug I'l describing, it may only be related to the newer 4.6.x firmware I mentioned in my OP.
I regret not noticing the default version on the first router which worked better.
Long story short, the bug I'm reporting is real. There are 3 or 4 other older reports about this pop-up ghost connection that appears for a minute or two on a power-up restart in the latest version.
It's likely not a malware issue but rather a "sloppy coding" issue.
I used to do software QC, and have a sharp pen, but am not a router expert. I just hate sloppy coding and software bugs. Because these kind of issues are a hacker's delight.
Anyway, I wont be posting going forward, but with 4 reports of this issue, it's real.
