Hi, am just received my Brume 2 and noticed that no VPN application on the router.
May i know what is going on and how to connect VPN ?
Thanks!
Thanks!
Did you upgrade to the latest v4.1.1 firmware ?
Yes, i did but stilk same
No vpn and no adguard home functions
It’s really weird, maybe you should do a factory reset or Uboot it.
Already reset but still same. I just received the product by today only.
It’s strange to have a “CN” label there even I change my language to Simplified Chinese, I don’t see the label there.
(is there any “China” only firmware version available ? )
Is this is a fake as i just received it by today?
What should i do now since vpn applications is not available on the router?
Uboot it again with firmware source “https://fw.gl-inet.com/firmware/mt2500/release/openwrt-mt2500-4.1.1-1105-1667584249.bin” to see what will happen. (I assumed that you only press the “Reset” hardware button to go through “factory reset” procedure only.)
Yes, i have uboot the router with the firmware but unfortunately still same as no vpn applications?
Is this a China set send it to me since the admin panel CN labeled?
Calling @alzhao for help.
Your customer support is already help me to resolve the issue. Excellent customer support especially 小龙 . Btw, thanks ![]()
so…what happened to your router ?
We are not supporting VPN and Adguard Home function for products sold in China.
So pls do not buy from Taobao if you are not in China.
