We are working with antenna supplier now to design a Dome antenna, this Dome antenna will include 6 antennas which can match the Spitz AX SMA interfaces, and one of the antenna supports both 5G and GPS signal.
The diameter of Dome antenna is 160~200mm, not very big, but not suitable for car usage, as can’t drill a hole on the car. For car used antenna, we need to consider the antenna shape and how to install it on top of car.
One Spitz AX antenna interface with silk-print ‘DIV/GNSS’, which can accept 5G and GPS signal, but need a Dome antenna to support it, and this antenna is under developing with our antenna supplier now. We will push the progress but not have an concrete plan to publish it so far.
On a different note, it’s also a quite compelling mobile Internet option in case you find yourself working on the go without a power outlet nearby. 9W is under load. Idle is more like 6W.
I’m looking for a way to do this on the X3000 just like I can on the X300-GPS. If you have anything ready (beta or not) I’d love to test this out. Right now on the X300 I report my GPS to a lan node-red server and then forward that to googcloud. Even if you have a rough draft that would be helpful.
The Dome antenna needs drilling a hole on the RV roof. We are arranging the performance test now, and plan to finish the test in one month. After that, we will add the antenna recommendation in the X3000 product page.
Thanks for quickly replying. I understand the dome antenna needs a hold necessary for cable going through. I was asking for mount options. Please have magnet mount options for class b rv. Most class b will have metal skin for magnetic mount and pre drilling cable box already. Please have magnet mount options. It will be very popular for pickup, class b, even some jeep or minivan.
