If the issue is easily reproducible, follow the steps below to share your device so you can troubleshoot it remotely
Technical Support via GoodCloud.tar (192 KB)
Still happening, and will share via GoodCloud.
For others:
firmware 4.4.12 and now just tried modem RM520NGLAAR01A08M4G_01.204.01.204
still happening.
@alzhao @Javon_ma
Same problem discount randomly with firmware version RM520NGLAAR03A03M4G.
Never any disconnect issue in last 6 month with RM520NGLAAR01A07M4G.
GL firmware: 0413release2
GL staff should look at this problem.
- also found bug : if disabled ping check multiwan for cellular then ipv6 not working even ipv6 already enable.
Ipv6 not working without enable ping check for multiwan (cellular)
Hi @mdpatel I have provide with you a new firmware. Would you mind to update to this FW and try it again?
Thank you for take your time.
successfully installed that you provided.
currently internet connected. but, i will message after 24 hours of use. how much stable or not.
Discount 2 times in 4 Hours.
Hi @mdpatel
Please tell me the name of the SIM card operator's network.Thanks!
I appear to be having the same issue as @mdpatel . Can I also please get the updated firmware? I am on: 0413release2 and cellular firmware: RM520NGLAAR03A03M4G . Attached are my logs. As you will see I lose IP address at Sat Jan 4 17:03:15 2025. This happens very frequently. I am on provider: EE (United Kingdom).
logread-6.tar (159 KB)
My original firmware version was RM520NGLAAR01A07M4G. After updating to RM520NGLAAR03A03M4G, I faced internet instability issues. then i installed the latest firmware, RM520NGLAAR01A08M4G_01.205.01.205, and haven't experienced a single disconnect in the past two days.
I downloaded this firmware from this link:
I tested multiple R03 and R01 firmware versions, and in my case, I found that R01 firmware versions are provide stable internet comprare to R03.
all firmware tested with GL.inet firmware version:
0413release2
i am using same version since 3 day. no single disconnect yet.
Hi @liamfoneill @mdpatel in view of the instability of the R03 version, we are advancing Quectel analysis, perhaps R03 has modified some configuration items, resulting in frequent network disconnection, please use R01 first, and I will share the results with you immediately.Thanks!
Ive been suggesting R01 for a long time and it is indeed much stable even in our own standalone setup compared to R03 branch.
Does anyone actually know the difference between R01 and R03?
FWIW, my router came with RM520NGLAAR01A08M4G_01.205.01.205 and it's been faultless....so far!
